Better G81 hole centre display?
21 Apr 2011 15:59 #9229 by stevec
Better G81 hole centre display? was created by stevec
I use EMC2 for pcb drilling and it works very well, but with one small niggle.
With the screen display looking down directly on the Z axis the G81 hole centres do not show at all, the view has to be tilted slightly before they can be seen.
With closely spaced hole centres this makes it difficult to be certain that I am checking the alignment of the machine & board on the same holes.
Is there a way of changing the hole centre display?
21 Apr 2011 23:44 #9244 by andypugh
Replied by andypugh on topic Re:Better G81 hole centre display?
I assume the problem is that a 1-pixel downfeed line viewed end-on is a bit subtle?
I can see the problem, I am struggling to think what the best solution is.
Time to create page: 0.051 seconds
