- Thank you received: 19
pyVCP button to control generic digital out
- oddwick
- Topic Author
5 years 9 months ago #196150
by oddwick
pyVCP button to control generic digital out was created by oddwick
Just curious if this is even possible. I have searched the forum and to be honest i am not really sure what to search for. what i am trying to do is create a pyvcp button to toggle a digital output. specifically with a mesa 7i96 using one of the general outputs to turn on and off an extraction fan. i can do it using an M code, but i would really like to do it with a button and toggle if possible. any ideas?
5 years 9 months ago #196160
Replied by tommylight on topic pyVCP button to control generic digital out
It should be,
www.anderswallin.net/tag/pyvcp/
linuxcnc.org/docs/2.8/html/gui/pyvcp.html
First link, second example should do what you need, or checkbutton on the second link, but the latter is very small.
- Thank you received: 1480
5 years 9 months ago - 5 years 9 months ago #196177
Replied by Todd Zuercher on topic pyVCP button to control generic digital out
Yes it very much is possible. It's even possible to have both a custom m-code and a vcp button. In fact it can make it easier. If you set up an m-code, you can trigger it with a halui mdi command with the vcp button.
Without the M-code you have to use either a hal toggle component, or a toggle button in your vcp.
Last edit: 5 years 9 months ago by Todd Zuercher.
- oddwick
- Topic Author
5 years 9 months ago #196265
by oddwick
Replied by oddwick on topic pyVCP button to control generic digital out
hey thanks tommy, i got that far, i have some buttons that turn on the pump and flood, and that works pretty well. and that example is pretty much what i had going, but where i got lost there seems to be no attributes that i can set for motion.digital-out-NN. like with mist, there is halui.mist.on/halui.mist.off etc. that i can manipulate. how do i do that with digital-out?
is it better to use the m-code? that is what i use (o subs anyway) to do generic canned operations like parking head, probe touch off. but how would i actually toggle it or would the m code toggle it when its called? if i used a mdi command, can it process logic or access machine variables?Todd Zuercher wrote: Without the M-code you have to use either a hal toggle component, or a toggle button in your vcp.
- chris@cnc
- Thank you received: 140
5 years 9 months ago - 5 years 9 months ago #196270
by chris@cnc
Replied by chris@cnc on topic pyVCP button to control generic digital out
not sure what do you want do with motion but i think you want enter some straight postion or switch on or off somthing.
I do also some off this and here my exmaple.
First button is for touching tool. I use a old style dial indicator and touch always 100mm top of the surface.
Second is for laser switch on and after find X and Y i set position. In my case not zero mounted.
And "Parkpositon" is drive to front or rearside.
Warning: Spoiler!
ini file to enter postion
[HALUI]
MDI_COMMAND = G10 L20 P0 X83 ( Set X to 83.000)
MDI_COMMAND = G10 L20 P0 Y-38 ( Set Y to -38.000 )
MDI_COMMAND = G10 L20 P0 Z0 ( Set Z to zero )
MDI_COMMAND = G10 L20 P0 Z100 ( Set Z to 100 )
MDI_COMMAND = G0 G53 X100 Y10 Z-10 (Park Position 1)
MDI_COMMAND = G0 G53 Y1000 Z-10 (Park Position 2)
hal file for IO
## --- Antasten ----
net MDI-x0 pyvcp.MDI-x0 halui.mdi-command-00
net MDI-y0 pyvcp.MDI-y0 halui.mdi-command-01
net MDI-z0 pyvcp.MDI-z0 halui.mdi-command-02
net MDI-z100 pyvcp.MDI-z100 halui.mdi-command-03
net Park-1 pyvcp.Park-1 halui.mdi-command-04
net Park-2 pyvcp.Park-2 halui.mdi-command-05
# --- Laser An ---
net laser-button hm2_7i76e.0.7i76.0.0.output-02 pyvcp.status-laser pyvcp.laser-an
XML code
<!-- Antasten-->
<label>
<text> "Antasten" </text>
<font>("Helvetica",14)</font>
</label>
<hbox>
<relief>RAISED</relief>
<button>
<halpin>"MDI-z100"</halpin>
<text>"Z=100.000"</text>
<bd>4</bd>
</button>
</hbox>
<hbox>
<checkbutton>
<halpin>"laser-an"</halpin>
<text>"Laser An"</text>
</checkbutton>
<led>
<halpin>"status-laser"</halpin>
<size>25</size>
<on_color>"green"</on_color>
<off_color>"red"</off_color>
</led>
<button>
<halpin>"MDI-x0"</halpin>
<text>"X=83.000"</text>
<bd>4</bd>
</button>
<button>
<halpin>"MDI-y0"</halpin>
<text>"Y=-38.000"</text>
<bd>4</bd>
</button>
<button>
<halpin>"MDI-z0"</halpin>
<text>"Z=0.000"</text>
<bd>4</bd>
</button>
</hbox>
<!-- Parkposition-->
<label>
<text> "Parkposition" </text>
</label>
<hbox>
<button>
<halpin>"Park-1"</halpin>
<text>"G0 G53 X100 Y10 Z-10"</text>
<bd>4</bd>
</button>
<button>
<halpin>"Park-2"</halpin>
<text>"G0 G53 Y1000 Z-10"</text>
<bd>4</bd>
</button>
</hbox>
</pyvcp>
Last edit: 5 years 9 months ago by chris@cnc.
5 years 9 months ago #196275
A custom M-code can be pretty much any executable file, but is usually a Bash or Python script. In it's simplest form it may be just a bash script that executes a halrun command to setp the value of a hal input pin. The hal pin will then hold that value until it is changed by something else. (You have to remember though, you can't setp a hal input pin if it is already connected to an output.)
What might be the best approach will depend on the complexity of what you're trying to accomplish.
Unfortunately custom m-codes can't contain g-code, so o-sub logic and machine parameter variables aren't available. But you can do that by remapping an m-code.
5 years 9 months ago #196278
Replied by rodw on topic pyVCP button to control generic digital out
Its not often done, but it is possible to maintain a separate pin inside your screen handler that is set by a screen control or by analog or digital input. Its a long time since I've done it but it does work.
- oddwick
- Topic Author
5 years 8 months ago #197926
by oddwick
so for what i am trying to do, that is a bit of overkill. basically i just need to hit button on screen and toggle one of the digital outputs on a 7i96. i would think that it would have been simpler than that. i can do it with the mist and flood, but i have two more that need to do the same thing to...
Now, when you say m code can be any executable, that really peaks my interest for other things. BUT, (there's always a but) you say that one cant pass machine parameters to it unless you remap it. could you elaborate?
5 years 8 months ago #197950
This very old example with help from islander261 is extracted from a python screen handler file for Gmocappy
In this case an analog input is connected to a pin called command-from-file in the handler
Different numeric ranges sent by M67/M68 override the screen controls
So in your case you could connect the screen button to your fan and set it from gcode as well...
Warning: Spoiler!
#ISLANDER - input for control codes from gcode file (M67 E0 & M68 E0)
self.command_from_file = hal_glib.GPin(halcomp.newpin("command-from-file", hal.HAL_FLOAT, hal.HAL_IN))
self.lock_height = hal_glib.GPin(halcomp.newpin("lock-height-from-file", hal.HAL_BIT, hal.HAL_OUT))
self.halcomp["lock-height-from-file"] = False
#ISLANDER - service command from gcode
self.command_from_file.connect("value-changed", self.on_new_command_from_file)
self.hal_btn_THC = self.builder.get_object("hal-btn-THC")
#ISLANDER - this function is used to decode command from gcode file
# if real time control of height hold is desired then 1X and 2X need to be
# decoded in a realtime component
def on_new_command_from_file(self, hal_pin, data = None):
if hal_pin.get() != 0:
command = hal_pin.get()
#THC run from file
if 20 <= command < 30:
#no need to decode I% here no Hypertherm RS-485
# height hold from file
elif 10 <= command < 20:
self.halcomp["lock-height-from-file"] = True
#global THC on
elif 900 == command:
#self.hal_btn_THC.set_active(True)
self.halcomp["hal-btn-THC"] = True
# global THC off
elif 999 == command:
#self.hal_btn_THC.set_active(False)
self.halcomp["hal-btn-THC"] = False
#get arc voltage
elif 360 <= command < 400 or 3060 <= command < 3201:
if command >= 3060:
command = command - 3000
else:
self.halcomp["target-voltage"] = command
self.lbl_prog_volt.set_label("%d" % command)
#get preset Amps not actually used
elif 410 <= command < 500 or 4000 <= command < 4201:
if command >= 4000:
command = command - 4000
else:
#nothing else to do here for now
#get arc servo delay time
elif 50 <= command < 60 or 500 <= command < 600:
if command >= 500:
command = (command - 500)
else:
command = command - 50
self.adj_THC_delay.set_value(command)
#get THC tune
elif 710 <= command < 720:
command = command - 710
#nothing to set yet
elif 80 <= command < 90 or 800 <= command < 900:
if command >= 800:
command = (command - 800)
else:
command = command - 80
self.adj_pierce_delay.set_value(command)
5 years 8 months ago #198105
Replied by andypugh on topic pyVCP button to control generic digital out
If you just want to link an onscreen button to a physical IO pin it is just a case of making the control in a PyVCP panel and (in HAL) connecting the pyvcp pin to the io pin.
It would be as simple as
net this-pin pyvcp.button -> hm2_7i96.0.gpio.000.out
Or similar.
Or similar.
Time to create page: 0.082 seconds
