pin "pyvcp.XXX" does not exist
  • greg23_78
  • Topic Author
  • Premium Member
  • Premium Member
2 years 4 months ago - 2 years 4 months ago #303836 by greg23_78
pin "pyvcp.XXX" does not exist was created by greg23_78
I have a problem with pyvcp commands.
am I missing something?
XML file
<labelframe text="TAILSTOCK">        <font>("Helvetica",16)</font>         <!-- le bouton de jog de la poupee mobile -->         <hbox>             <relief>RAISED</relief>             <bd>3</bd>             <button>                 <font>("Helvetica",20)</font>                 <width>3</width>                 <halpin>"tailstock-plus"</halpin>                 <text>"H+"</text>             </button>             <button>                 <font>("Helvetica",20)</font>                 <width>3</width>                 <halpin>"tailstock-moins"</halpin>                 <text>"H-"</text>             </button>         </hbox>     </labelframe>     <labelframe text="CONVOYOR">        <font>("Helvetica",16)</font>         <!-- le bouton de jog de la poupee mobile -->         <hbox>             <relief>RAISED</relief>             <bd>3</bd>             <button>                 <font>("Helvetica",20)</font>                 <width>3</width>                 <halpin>"convoyor-rev"</halpin>                 <text>"RV"</text>             </button>             <button>                 <font>("Helvetica",20)</font>                 <width>3</width>                 <halpin>"convoyor-fwd"</halpin>                 <text>"FW"</text>             </button>         </hbox>     </labelframe>
INI file
HAL] HALFILE = main.hal HALFILE = io.hal HALFILE = sserial.hal HALFILE = custom.hal HALFILE = Carousel.hal POSTGUI_HALFILE = postgui.hal SHUTDOWN = shutdown.hal HALUI = halui
Postgui file
show pin # Put HAL commands in this file that you want to run after the GUI loads net tailstock-moins     =>      pyvcp.tailstock-moins net tailstock-plus      =>      pyvcp.tailstock-plus net convoyor-rev        =>      pyvcp.convoyor-rev net convoyor-fwd        =>      pyvcp.convoyor-fwd
Hal file
# PyVCP button # loadrt and2 names=and2_tailstock_manu_moins,and2_tailstock_manu_plus loadrt or2 names=or2_tailstock_manu_auto_moins,or2_tailstock_manu_auto_plus addf and2_tailstock_manu_moins           servo-thread addf and2_tailstock_manu_plus            servo-thread addf or2_tailstock_manu_auto_moins       servo-thread addf or2_tailstock_manu_auto_plus        servo-thread net program_no_running     halui.program.is-idle net program_no_running        and2_tailstock_manu_moins.in0 net program_no_running     and2_tailstock_manu_plus.in0 # headstock net my-jogtailstock-moins-auto            motion.digital-out-00 net my-jogtailstock-moins                 tailstock-moins and2_tailstock_manu_moins.in1 net my-jogtailstock-moins-manu            and2_tailstock_manu_moins.out => or2_tailstock_manu_auto_moins.in0 net my-jogtailstock-moins-manu-auto       or2_tailstock_manu_auto_moins.out => hm2_7i97.0.7i84.0.0.output-00 net my-jogtailstock-plus-auto            motion.digital-out-01 net my-jogtailstock-plus                 tailstock-plus and2_tailstock_manu_plus.in1 net my-jogtailstock-plus-manu            and2_tailstock_manu_plus.out => or2_tailstock_manu_auto_plus.in0 net my-jogtailstock-plus-manu-auto       or2_tailstock_manu_auto_plus.out => hm2_7i97.0.7i84.0.0.output-01 # convoyor net my-jogconvoyor-rev     hm2_7i97.0.7i84.0.0.output-02 <= convoyor-rev net my-jogconvoyor-fwd     hm2_7i97.0.7i84.0.0.output-03 <= convoyor-fwd
Last edit: 2 years 4 months ago by greg23_78.
2 years 4 months ago #303842 by roland
Replied by roland on topic pin "pyvcp.XXX" does not exist
Missing entry in the DISPLAY section of the iNI file?
  • greg23_78
  • Topic Author
  • Premium Member
  • Premium Member
2 years 4 months ago #303844 by greg23_78
Replied by greg23_78 on topic pin "pyvcp.XXX" does not exist
[DISPLAY] DISPLAY = axis EDITOR = mousepad PROGRAM_PREFIX = /home/cnc/linuxcnc/nc_files POSITION_OFFSET = RELATIVE POSITION_FEEDBACK = ACTUAL MAX_FEED_OVERRIDE = 1.2 MIN_LINEAR_VELOCITY = 0.5 DEFAULT_LINEAR_VELOCITY = 6.0 MAX_LINEAR_VELOCITY = 133.3 INCREMENTS = 5mm 1mm .5mm .1mm .05mm .01mm CYCLE_TIME = 0.1 INTRO_GRAPHIC = emc2.gif INTRO_TIME = 3 OPEN_FILE = "" PYVCP = cnc_samua.xml LATHE = 1
name of my xml file : cnc_samua.xml
2 years 4 months ago #303850 by Aciera
Replied by Aciera on topic pin "pyvcp.XXX" does not exist
Have you tried to start your config from a terminal to check for error messages in the output?
$ linuxcnc
  • greg23_78
  • Topic Author
  • Premium Member
  • Premium Member
2 years 4 months ago #303851 by greg23_78
cnc@cnc:~$ linuxcnc LINUXCNC - 2.9.2 Machine configuration directory is '/home/cnc/linuxcnc/configs/cnc_samua' Machine configuration file is 'cnc_samua.ini' Starting LinuxCNC... linuxcnc TPMOD=tpmod HOMEMOD=homemod EMCMOT=motmod Note: Using POSIX realtime Found file(REL): ./main.hal hm2: loading Mesa HostMot2 driver version 0.15 hm2_eth: loading Mesa AnyIO HostMot2 ethernet driver version 0.2 hm2_eth: 10.10.10.10: INFO: Hardware address (MAC): 00:60:1b:17:80:02 hm2_eth: discovered 7I97T hm2/hm2_7i97.0: Low Level init 0.15 hm2/hm2_7i97.0: Smart Serial Firmware Version 43 Board hm2_7i97.0.7i84.0.0 Hardware Mode 0 = standard Board hm2_7i97.0.7i84.0.0 Software Mode 0 = input_output Board hm2_7i97.0.7i84.0.0 Software Mode 1 = io_analog_fieldvoltage Board hm2_7i97.0.7i84.0.0 Software Mode 2 = io_encoder_analog hm2/hm2_7i97.0: 51 I/O Pins used: hm2/hm2_7i97.0:     IO Pin 000 (TB3-04): PWMGen #0, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 001 (TB3-08): PWMGen #1, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 002 (TB3-12): PWMGen #2, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 003 (TB3-16): PWMGen #3, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 004 (TB3-20): PWMGen #4, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 005 (AN_ENA4): PWMGen #4, pin Not-Enable (Output) hm2/hm2_7i97.0:     IO Pin 006 (TB3-24): PWMGen #5, pin Out0 (PWM or Up) (Output) hm2/hm2_7i97.0:     IO Pin 007 (AN_ENA5): PWMGen #5, pin Not-Enable (Output) hm2/hm2_7i97.0:     IO Pin 008 (AN-ENA0..3): PWMGen #0, pin Not-Enable (Output) hm2/hm2_7i97.0:     IO Pin 009 (TB1-01/TB1-09): Muxed Encoder #0, pin Muxed A (Input) hm2/hm2_7i97.0:     IO Pin 010 (TB1-04/TB1-12): Muxed Encoder #0, pin Muxed B (Input) hm2/hm2_7i97.0:     IO Pin 011 (TB1-07/TB1-15): Muxed Encoder #0, pin Muxed Index (Input) hm2/hm2_7i97.0:     IO Pin 012 (TB1-17/TB2-01): Muxed Encoder #1, pin Muxed A (Input) hm2/hm2_7i97.0:     IO Pin 013 (TB1-20/TB2-04): Muxed Encoder #1, pin Muxed B (Input) hm2/hm2_7i97.0:     IO Pin 014 (TB1-23/TB2-07): Muxed Encoder #1, pin Muxed Index (Input) hm2/hm2_7i97.0:     IO Pin 015 (TB2-09/TB2-17): Muxed Encoder #2, pin Muxed A (Input) hm2/hm2_7i97.0:     IO Pin 016 (TB2-12/TB2-20): Muxed Encoder #2, pin Muxed B (Input) hm2/hm2_7i97.0:     IO Pin 017 (TB2-15/TB2-23): Muxed Encoder #2, pin Muxed Index (Input) hm2/hm2_7i97.0:     IO Pin 018 (Internal EncMux): Muxed Encoder Select #0, pin Mux Select 0 (Output) hm2/hm2_7i97.0:     IO Pin 019 (TB5-13/TB5-14): SSR #0, pin Out-00 (Output) hm2/hm2_7i97.0:     IO Pin 020 (TB5-15/TB5-16): SSR #0, pin Out-01 (Output) hm2/hm2_7i97.0:     IO Pin 021 (TB5-17/TB5-18): SSR #0, pin Out-02 (Output) hm2/hm2_7i97.0:     IO Pin 022 (TB5-19/TB5-20): SSR #0, pin Out-03 (Output) hm2/hm2_7i97.0:     IO Pin 023 (TB5-21/TB5-22): SSR #0, pin Out-04 (Output) hm2/hm2_7i97.0:     IO Pin 024 (TB5-23/TB5-24): SSR #0, pin Out-05 (Output) hm2/hm2_7i97.0:     IO Pin 025 (Internal InMux0): SSR #0, pin AC Ref (internal) (Output) hm2/hm2_7i97.0:     IO Pin 026 (Internal InMux1): InMux Input Mux #0, pin addr0 (Output) hm2/hm2_7i97.0:     IO Pin 027 (Internal InMux2): InMux Input Mux #0, pin addr1 (Output) hm2/hm2_7i97.0:     IO Pin 028 (Internal InMux3): InMux Input Mux #0, pin addr2 (Output) hm2/hm2_7i97.0:     IO Pin 029 (Internal InMuxData): InMux Input Mux #0, pin addr3 (Output) hm2/hm2_7i97.0:     IO Pin 030 (TB4-15/TB4-16): InMux Input Mux #0, pin muxdata (Input) hm2/hm2_7i97.0:     IO Pin 031 (TB4-17/TB4-18): Smart Serial Interface #0, pin rx0 (Input) hm2/hm2_7i97.0:     IO Pin 032 (TB4-17/TB4-18): Smart Serial Interface #0, pin tx0 (Output) hm2/hm2_7i97.0:     IO Pin 033 (P1-01/DB25-01): Smart Serial Interface #0, pin txen0 (Output) hm2/hm2_7i97.0:     IO Pin 034 (P1-02/DB25-14): IOPort hm2/hm2_7i97.0:     IO Pin 035 (P1-03/DB25-02): IOPort hm2/hm2_7i97.0:     IO Pin 036 (P1-04/DB25-15): IOPort hm2/hm2_7i97.0:     IO Pin 037 (P1-05/DB25-03): IOPort hm2/hm2_7i97.0:     IO Pin 038 (P1-06/DB25-16): IOPort hm2/hm2_7i97.0:     IO Pin 039 (P1-07/DB25-04): IOPort hm2/hm2_7i97.0:     IO Pin 040 (P1-08/DB25-17): IOPort hm2/hm2_7i97.0:     IO Pin 041 (P1-09/DB25-05): IOPort hm2/hm2_7i97.0:     IO Pin 042 (P1-11/DB25-06): IOPort hm2/hm2_7i97.0:     IO Pin 043 (P1-13/DB25-07): IOPort hm2/hm2_7i97.0:     IO Pin 044 (P1-15/DB25-08): IOPort hm2/hm2_7i97.0:     IO Pin 045 (P1-17/DB25-09): IOPort hm2/hm2_7i97.0:     IO Pin 046 (P1-19/DB25-10): IOPort hm2/hm2_7i97.0:     IO Pin 047 (P1-21/DB25-11): IOPort hm2/hm2_7i97.0:     IO Pin 048 (P1-23/DB25-12): IOPort hm2/hm2_7i97.0:     IO Pin 049 (P1-25/DB25-13): IOPort hm2/hm2_7i97.0: registered ./main.hal:176: Pin 'convoyor-rev' does not exist Shutting down and cleaning up LinuxCNC... Running HAL shutdown script iov2: exiting hm2_eth: in hm2_eth_reset hm2_eth: HostMot2 ethernet driver unloaded hm2: unloading Note: Using POSIX realtime LinuxCNC terminated with an error.  You can find more information in the log:     /home/cnc/linuxcnc_debug.txt and     /home/cnc/linuxcnc_print.txt as well as in the output of the shell command 'dmesg' and in the terminal
  • greg23_78
  • Topic Author
  • Premium Member
  • Premium Member
2 years 4 months ago #303852 by greg23_78
I commented on the tailstock part for the test.
That's why the error is on the conveyor.
2 years 4 months ago #303853 by tommylight
Replied by tommylight on topic pin "pyvcp.XXX" does not exist
Both lines at the end, you can not just make up pins, those must exist before connecting them:
- my-jogconvoyor-rev <<< this is OK a pin you are creating, think of it as a bus bar with that name
- convoyor-rev <<< at the end is not OK as it does not exist
-- net means "connect", so you connect the hm2_7i97.0.7i84.0.0.output-02 to the bus bar named "my-jogconvoyor-rev" and you also tried to connect the convoyor-rev that does not exist
Two options:
1- remove the 2 non existing names/pins and use the existing pins in your PyVCP hal file
2- rename the existing pins with the non existing ones.
The following user(s) said Thank You: greg23_78
Time to create page: 0.062 seconds
