pin "pyvcp.XXX" does not exist
2 years 4 months ago #303853 by tommylight
# convoyor net my-jogconvoyor-rev hm2_7i97.0.7i84.0.0.output-02 <= convoyor-rev net my-jogconvoyor-fwd hm2_7i97.0.7i84.0.0.output-03 <= convoyor-fwd
Both lines at the end, you can not just make up pins, those must exist before connecting them:
- my-jogconvoyor-rev <<< this is OK a pin you are creating, think of it as a bus bar with that name
- convoyor-rev <<< at the end is not OK as it does not exist
-- net means "connect", so you connect the hm2_7i97.0.7i84.0.0.output-02 to the bus bar named "my-jogconvoyor-rev" and you also tried to connect the convoyor-rev that does not exist
Two options:
1- remove the 2 non existing names/pins and use the existing pins in your PyVCP hal file
2- rename the existing pins with the non existing ones.
The following user(s) said Thank You: greg23_78
Time to create page: 0.190 seconds
