ERROR: Button to run a simple routine
  • Askjerry
  • Topic Author
  • Elite Member
  • Elite Member
2 years 2 days ago #313769 by Askjerry
ERROR: Button to run a simple routine was created by Askjerry
I have built over 40 pyvcp panels in my life... and I have a button that runs a simple routine to safely go home.
Lift the Z, move to the XY, lower the Z. Simple... here is the code.
O<safe-go-home> sub
G90 G20
M5
M9
G53 G0 Z 0
G0 X0 Y0
G0 Z0
O<safe-go-home> endsub
The panel has a button with a halpin: safe-go-home
And the custom_postgui.hal has
net panel-safe-go-home  <= halui.mdi-command-00  <= pyvcp.safe-go-home
And lastly, the INI has...
[HALUI]
# add halui MDI commands here (max 64)
MDI_COMMAND = O <safe-go-home>         CALL
All the components I've used like 40 times before.
Now... on this machine... I'm getting...
EOF in file:/usr/share/axis/images/axis.ngc seeking o-word o<safe-go-home> from line 0
What the heck?
2 years 2 days ago #313771 by Aciera
Replied by Aciera on topic ERROR: Button to run a simple routine
Doesn't sound like a problem with your pyvcp panel but rather with your subroutine path.
Have you tried running this in the MDI command input:
o<safe-go-home> call
If that gives you the same error, which I would expect, then check that you have placed the file 'save-go-home.ngc' in a directory listed in PROGRAM_PREFIX or SUBROUTINE_PATH in your INI file.
2 years 2 days ago - 2 years 2 days ago #313772 by spumco
Replied by spumco on topic ERROR: Button to run a simple routine
I don't know if this is it, but if that's a copy-paste from your INI file it looks like there's a space between "O" and "<safe-go-home>"
So I'd check if there's a space, as well as double-checking the subroutine path in INI file.
EDIT: Aciera beat me to it.  Again.image missing /media/kunena/emoticons/smile.png
Last edit: 2 years 2 days ago by spumco.
The following user(s) said Thank You: tommylight, Aciera
2 years 2 days ago #313782 by MaHa
Replied by MaHa on topic ERROR: Button to run a simple routine
I had bad experience with capital letters in naming of subroutines.
try a lovercase 'o'
O<safe-go-home> sub
  • Askjerry
  • Topic Author
  • Elite Member
  • Elite Member
2 years 2 days ago - 2 years 2 days ago #313789 by Askjerry
Replied by Askjerry on topic ERROR: Button to run a simple routine
ERROR - INSERT COFFEE!!! Thanks Aciera !!
DERP...
What it is SUPPOSED to be... like in My Laguna config...
[RS274NGC]
PARAMETER_FILE = linuxcnc.var
SUBROUTINE_PATH = ./ROUTINES/
FEATURES = 12
What did I have???
[RS274NGC]
Jeeze... ok then... problem resolved!
Thanks for the kick in the head to get me restarted!!!
Last edit: 2 years 2 days ago by Askjerry.
Time to create page: 0.060 seconds
