spinbox problem
  • jefsaro
  • jefsaro's Avatar Topic Author
  • Premium Member
  • Premium Member
21 Apr 2026 16:59 #345815 by jefsaro
spinbox problem was created by jefsaro
bonjour ,
je viens de passer de linux 2.5.4 de ma mortaiseuse a 2.9.5, le probleme, est que les signaus de spinbox ne passe plus .j 'ai lu qu il y avais un changement de pyton , j 'ai essayer plusieurs piset et changer post-gui halfile , mais rien ne chan,ge , pouvez vous m 'aider ?
  • Moderator
  • Moderator
03 May 2026 04:56 #346125 by tommylight
Replied by tommylight on topic spinbox problem
Google translation:
I just upgraded my mortiser from Linux 2.5.4 to 2.9.5, but the problem is that Spinbox signals are no longer working. I read that there was a change in Python, I tried several Python scripts and changed Post-GUI Halfile, but nothing changed. Can you help me?
What is the exact error you get?
03 May 2026 10:21 #346131 by rodw
Replied by rodw on topic spinbox problem
The problem is that python 2.7 which you use was deprecated with the release of Debian Bullseye in favour of Python 3. The only solution is to rewrite you scripts using Python 3. Python 2.7 and 3.0 are not compatible.
The following user(s) said Thank You: jefsaro
03 May 2026 11:44 - 03 May 2026 19:01 #346132 by MaHa
Replied by MaHa on topic spinbox problem
The entry for python is missing in ini file. In my config, its after [RS274NGC]
Make shure toplevel.py is in the path, and  stdglue.py if needed for remap
[PYTHON]
PATH_PREPEND= /home/jef/linuxcnc/configs/Python/
PATH_APPEND=  /home/jef/linuxcnc/configs/Python/
TOPLEVEL= /home/jef/linuxcnc/configs/Python/toplevel.py
Edit:
I was wrong with the python entry. PYVCP panel works without that
Last edit: 03 May 2026 19:01 by MaHa.
  • jefsaro
  • Premium Member
  • Premium Member
02 Sep 2026 06:23 - 02 Sep 2026 07:51 #349208 by jefsaro
Replied by jefsaro on topic spinbox problem
look latency test
 today morning is ok, no problem ,after 1h30 alarm and stop , what is it???????
Last edit: 02 Sep 2026 07:51 by jefsaro.
Time to create page: 0.092 seconds
