Small guidline...
- frequency
17 Nov 2011 06:50 #14887
by frequency
Small guidline... was created by frequency
Hy!
I 'm new at EMC and Linux Ubuntu so i have a few questions for building own components.
I had installed EMC + Ubuntu with Live CD.
The way to do i think:
1.) Write my C code for the component with a text editor and put it into emc2/src/hal/components with file extension .comp .
2.) Run comp.
Is this correct?
But i can“t find the path "emc2/src/hal/components" ?? Need i some more installation of EMC?
Many thanks in advance
Wolfgang
2.) Run comp.
Is this correct?
Wolfgang
- Thank you received: 2162
17 Nov 2011 08:33 #14889
Replied by cmorley on topic Re:Small guidline...
try this:
www.linuxcnc.org/docs/2.4/html/hal_comp....-realtime-components
I think that works without downloading the source...
- ArcEye
- Thank you received: 758
17 Nov 2011 11:24 #14892
by ArcEye
Replied by ArcEye on topic Re:Small guidline...
Hi
You will only have .../emc2/src/hal/components if you are compiling emc from sources.
I don't know if configure would add in your component automatically or whether you would have to edit makefile.in
If I just want to add a single component to an already installed emc system, I just put the mycomponent.comp file in either the
~/emc2/configs directory that relates to the machine the component is to be used on
or in the root of the .../emc-dev/ directory if using on a RIP build.
That is just so I know where to look for source code, comp takes care of installing the compiled component.
From that directory (remembering to set the emc-environment if a RIP) run
sudo comp --install mycomponent.comp
and subject to your code being correct, it will be compiled and installed.
- Thank you received: 4994
17 Nov 2011 11:48 #14894
Replied by andypugh on topic Re:Small guidline...
ArcEye wrote:
The makefile automatically compiles everything in the components directory. However, that is only any use if you want to recompile the whole of EMC2, so isn't what I would reccomend in this case. The comp --install way is much simpler.You will only have .../emc2/src/hal/components if you are compiling emc from sources.
- frequency
17 Nov 2011 13:14 #14895
by frequency
Replied by frequency on topic Re:Small guidline...
Is it possible to find a describtion for this task, so that a person without much Linux experience like me can do this?
thanks
thanks
17 Nov 2011 14:29 #14897
frequency wrote:
If you go back to the link John posted, and scroll to the beginning you might find what you want.Is it possible to find a describtion for this task, so that a person without much Linux experience like me can do this?
- frequency
17 Nov 2011 15:56 #14903
by frequency
Ok! I will try it.
Thank you
Thank you
Time to create page: 0.059 seconds
