how to connect the two outputs into one signal ?
- dzarek
17 Jan 2012 21:55 #16860
by dzarek
how to connect the two outputs into one signal ? was created by dzarek
Hi
I want to plug in inputs "pyvcp.x-home" and "parport.0.pin-12-in-not" to "halui.joint.0.home".
The first entry is in the pyvcp hal file, the second in custom.hal
How to do it ? Because I gets only errors, for example:
panel.hal:4: Signal 'my-homex' can not add OUT pin 'parport.0.pin-12-in-not', it already has OUT pin 'pyvcp.x-home'
- BigJohnT
- Thank you received: 1176
17 Jan 2012 22:03 #16862
by BigJohnT
Replied by BigJohnT on topic Re:how to connect the two outputs into one signal ?
You just can't have two out pins on one signal.
Please read this for a thorough explanation.
linuxcnc.org/docview/2.5/html/hal/basic_hal.html
What are you trying to do?
- dzarek
18 Jan 2012 08:09 #16871
by dzarek
Replied by dzarek on topic Re:how to connect the two outputs into one signal ?
I want to run HomeX from the pyvcp and external input.
In the topic I confused something with the word "outputs"
I read the link you provided, today I check of or2 component.
Time to create page: 0.051 seconds
