userspace python/HAL component not becoming ready
22 Jan 2012 06:24 #17011 by tensaiteki
I am building a reprap machine where the motors are controlled by EMC2 (err.... I mean LinuxCNC) and a TB6560 board and the extruder heater and thermocouple are controlled by a standard reprap aurdrino board.
I already have a PyVCP meter set up to display the current temperature of the extruder tip.
The problem is I can't seem to get the HAL component that queries the audrino to become ready.
The component I am using came from here: github.com/brendanjerwin/emcrepstrap/blo...tion/reprap-extruder
I had to modify it slightly to work with the newer reprap firmware, here is my modified version:
#!/usr/bin/env python
# encoding: utf-8
Created by Brendan Erwin on 2008-05-21.
Copyright (c) 2008 Brendan Erwin. All rights reserved.
Slightly Modified by Tensaiteki on 2012-01-21
This program is free software; you can redistribute it and/or
modify it under the terms of the GNU General Public License
as published by the Free Software Foundation; either version 2
of the License, or (at your option) any later version.
This program is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with this program; if not, write to the Free Software
Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301, USA.
import serial
import hal
import sys
import time
PORT = "/dev/ttyUSB0"
#allow the port to be overridden
if len(sys.argv) > 1:
    PORT = sys.argv[1]
#Establish serial link
ser = serial.Serial(PORT, 19200, timeout=2)
#Setup the HAL component and pins
c = hal.component("reprap-extruder")
c.newpin("temperature", hal.HAL_FLOAT, hal.HAL_IN)
c.ready()
data = ""
try:
	while 1:
		time.sleep(1)
		ser.write("M105\n")
		while ser.inWaiting():
			data += ser.read()
		if len(data) > 0:
			#print >> sys.stdout, data
			start = data.find("T:")
			if start <> -1:
				start += 2
				end = data.index("\r",start)
				print >> sys.stdout, data[start:end]
				c["temperature"] = int(data[start:end])
		data = ""
except KeyboardInterrupt:
    raise SystemExit
When I try to run LinuxCNC with "loadusr -W /home/reprap/emc2/configs/reprap/reprap-extruder /dev/ttyUSB0" in the HAL file, after the spalsh screen, I get nothing. No error messages, no Axis, nothing.
When I run the component under halrun it will keep printing out the current extruder temperature indefinitely until I force-stop it (Ctrl-C):
halcmd: loadusr -W /home/reprap/emc2/configs/reprap/reprap-extruder /dev/ttyUSB0
Waiting for component '/home/reprap/emc2/configs/reprap/reprap-extruder' to become ready.....................23
..........23
..........23
..........23
..........23
..........23
..........23
..........23
..........23
.........23
..........23
..........23
..........23
..........23
..........^C
<stdin>:2: /home/reprap/emc2/configs/reprap/reprap-extruder exited without becoming ready
If I comment out everything in the component after the .ready() function call (so the while loop never happens), I get the following under halrun:
halcmd:
I get the exact same message if I also comment out the c.ready() line.
However if I insert another c.ready() line anywhere else in the component, I get an error message saying that the component is already ready.
Any ideas what I am doing wrong?
System is Ubuntu 10.04 (installed from live CD) with LinuxCNC version 2.4.7 (updated via update manager).
22 Jan 2012 06:44 #17012 by cmorley
run emc after the crash check and post dmesg
hopefully a little clue will be there.
22 Jan 2012 06:48 #17013 by cmorley
just as a hunch try using a name without a - in it. a single word name.
22 Jan 2012 07:28 - 22 Jan 2012 07:29 #17014 by tensaiteki
Ok, if I run EMC with the reprap-extruder component in the hal file, it doesn't really crash after the splash screen. The spalsh screen just goes away and nothing happens until I try to start EMC again at which point I get a dialog box that says it is already running and asking if I want to restart EMC. If I click 'restart', then I get an error message:
(all the '23's are the output from the reprap-extruder component showing that the tip is at 23 degrees C.)
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/reprap/emc2/configs/reprap'
Machine configuration file is 'reprap.ini'
INIFILE=/home/reprap/emc2/configs/reprap/reprap.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=halui
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Starting EMC2 IO program: io
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
23
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=18995
Cleanup done
Debug file information:
Waiting for component '/home/reprap/emc2/configs/reprap/reprap-extruder' to become ready...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
custom.hal:6: /home/reprap/emc2/configs/reprap/reprap-extruder exited without becoming ready
18995
  PID TTY      STAT   TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib is in use by stepgen,hal_parport,probe_parport,motmod,trivkins
ERROR: Module rtapi is in use by stepgen,hal_parport,probe_parport,motmod,hal_lib
ERROR: Module rtai_math is in use by motmod
ERROR: Module rtai_sem is in use by rtapi
ERROR: Module rtai_fifos is in use by rtapi
ERROR: Module rtai_sched is in use by rtapi,rtai_sem,rtai_fifos
ERROR: Module rtai_hal is in use by rtapi,rtai_sem,rtai_fifos,rtai_sched
Kernel message information:
[188094.213601] I-pipe: Domain RTAI registered.
[188094.213620] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03.
[188094.213627] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) .
[188094.213750] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0).
[188094.213756] PIPELINE layers:
[188094.213763] fba20e20 9ac15d93 RTAI 200
[188094.213769] c085cb20 0 Linux 100
[188094.261086] RTAI[malloc]: global heap size = 2097152 bytes, <BSD>.
[188094.261778] RTAI[sched]: IMMEDIATE, MP, USER/KERNEL SPACE: <with RTAI OWN KTASKs>, kstacks pool size = 524288 bytes.
[188094.261790] RTAI[sched]: hard timer type/freq = APIC/12500388(Hz); default timing: periodic; linear timed lists.
[188094.261797] RTAI[sched]: Linux timer freq = 250 (Hz), TimeBase freq = 1799590000 hz.
[188094.261803] RTAI[sched]: timer setup = 999 ns, resched latency = 2944 ns.
[188094.261932] RTAI[usi]: enabled.
[188094.354084] RTAI[math]: loaded.
[188094.484852] config string '0x378 out  '
I tried renaming reprap-extruder to reprapextruder but got the exact same errors/behavior.
Last edit: 22 Jan 2012 07:29 by tensaiteki.
22 Jan 2012 09:06 #17015 by cmorley
ok another guess. -W tells HAL to wait for the component named as the next argument after -W.
your component has a path so I'm thinking the path is screwing it up. HAL thinks the components name is the complete path name.
add the component in your $PATH and then drop the path from the loadusr command
22 Jan 2012 09:08 #17016 by cmorley
lol now that I really read the error message :
for sure that is the problem.
22 Jan 2012 15:25 #17017 by tensaiteki
Sorry to sound like a n00b but how do I find out where $Path is?
I used the full path for the component because I couldn't figure out where HAL was looking for it otherwise.
I tried using the path for nc_files specified in the ini, but that didn't work.
I just re-read the HAL user manual and it makes one reference to $PATH but doesn't say where it is.
22 Jan 2012 16:31 - 22 Jan 2012 16:33 #17019 by ArcEye
Hi
Its a linux thing rather than HAL.
echo $PATH will display the current PATH settings
PATH=$PATH:/usr/new/path/added/
export PATH
will append a new path to the PATH environment variable
If you want this to be permanent for all your logins, then add the required paths to the PATH line in ~/.bashrc
Last edit: 22 Jan 2012 16:33 by ArcEye.
22 Jan 2012 16:38 #17020 by dab77
Try to put a copy of your reprap.py into ../emc2-dev/bin but without the .py extension, and give that permission to execute.
Then if you like you can put the halcmd inside your .hal file, like:
loadusr -W reprap
Davide.
22 Jan 2012 23:33 - 22 Jan 2012 23:34 #17027 by cmorley
We should probably add this to the manual in the python HAL section ...
Last edit: 22 Jan 2012 23:34 by cmorley.
