Can I use a C shell script for my PLC stuff?
- Thank you received: 5018
You can declare variables in the usual way after the ;; but they will be shared between all instances. (probably not a problem here)
- JR1050
- Thank you received: 33
root@jr1050-desktop:/usr/realtime-2.6.32-122-rtai/modules/emc2# comp --install buttonlogic.comp
File "/usr/bin/comp", line 1321, in <module>
main()
File "/usr/bin/comp", line 1290, in main
process(f, mode, outfile)
File "/usr/bin/comp", line 1164, in process
a, b = parse(filename)
File "/usr/bin/comp", line 404, in parse
a, b = f.split("\n;;\n", 1)
ValueError: need more than 1 value to unpack
they seem to be Python errors,comp appears to be written in python.....
main()
Yes, comp is a Python program which preprocesses .comp files into C files, and then compiles them.
It is sometimes helpful to do only the preprocessing step and to look at the resulting C code to see what has gone wrong.
However, if your problem is with the code listed earlier, then I have already explained that it is not a valid .comp, so you need to at least fix those problems first.
- JR1050
how do I run the pre processer?
The according to:
www.linuxcnc.org/docview/html/hal_comp.h...-realtime-components
if you run comp without any of the flags, that is what it does, it creates a c file from the comp file, and leaves it in the current directory.
Normally you comp --install, but that deletes the intermediate C-code after it has compiled it.
- BigJohnT
- Thank you received: 1177
So for the dumb question,how do I run the pre processer?I didnt see any reference to it in the comp section of the manual.....Thanks again
Plenty of examples of how to run comp in the manual...
linuxcnc.org/docview/2.5/html/hal/comp.h...s_in_the_source_tree
- JR1050
- BigJohnT
- JR1050
oot@jr1050-desktop:/usr/realtime-2.6.32-122-rtai/modules/emc2# comp constant.comp
main()
The same thing.The only file I could get to rum thru comp is an example file for an orac tool changer.What simple thing am i missing?What is this value error thing and what is the meaning of line 404 and its associated code.This shouldnt be this hard....
- JR1050
DUHHHH
