halui incremental jog
  • Rick G
  • Rick G's Avatar Topic Author
  • Junior Member
  • Junior Member
01 Feb 2012 19:55 #17324 by Rick G
halui incremental jog was created by Rick G
On 2.6 pre
When I enter
setp halui.jog.0.increment 0.1
setp halui.jog.0.increment-plus 1
In the test hal command area they are accepted and I can see the pins change.
I would expect one incremental jog of 0.1
However on Axis I see no results, am I missing something?
Rick G
02 Feb 2012 01:13 #17328 by cmorley
Replied by cmorley on topic Re:halui incremental jog
In Axis are you in manual mode?
  • Rick G
  • Junior Member
  • Junior Member
02 Feb 2012 12:05 #17335 by Rick G
Replied by Rick G on topic Re:halui incremental jog
Yes.
Just for fun I also tried MDI.
The other jog pins seem to work as expected in manual mode but not the above.
Rick G
02 Feb 2012 12:14 #17337 by BigJohnT
Replied by BigJohnT on topic Re:halui incremental jog
Rick,
Did you set the increment-plus back to 0? Maybe it needs the on to off transition... just an early morning SWAG.
  • Rick G
  • Junior Member
  • Junior Member
02 Feb 2012 12:33 #17339 by Rick G
Morning John,
Yes, I believe it does need the transition. I toggled it back and forth, also tried a oneshot.
Rick G
  • Rick G
  • Junior Member
  • Junior Member
06 Apr 2012 10:52 #19011 by Rick G
Turns out you need to set halui.jog-speed first to make this work.
Thanks to John for sorting this out.
Rick G
Time to create page: 0.061 seconds
