Unable to Reverse the Spindle
- BigJohnT
- Thank you received: 1176
09 Mar 2012 22:31 #18503
by BigJohnT
Replied by BigJohnT on topic Re:Unable to Reverse the Spindle
Do you have a direction pin on your spindle drive?
A short brush up on HAL is here
linuxcnc.org/docview/2.5/html/hal/basic_hal.html
In HAL you can only connect pins a certain way as explained in the link.
- thebuc
09 Mar 2012 22:37 #18504
by thebuc
Replied by thebuc on topic Re:Unable to Reverse the Spindle
Hey
So I figured it out. It was a bit of a syntax and naming pin issue. I basically had to shove an absolute value function inbetween all the gear change and current spindle stuff. The HAL file is attached.
Thanks for the motivation and help... most importantly quick help. HAha
- BigJohnT
09 Mar 2012 22:39 #18505
by BigJohnT
I'm just glad you got it sorted out!
Time to create page: 0.071 seconds
