rtapi_print_msg output
- frequency
02 Apr 2012 07:54 #18908
by frequency
rtapi_print_msg output was created by frequency
I´m still new at this topic
, so i hope anybody can give me some hints.
where can i see the output of "rtapi_print_msg(..)" ? I need it for debugging of my components written as .c.
cheers
Wolfgang
cheers
Wolfgang
- ArcEye
- Thank you received: 758
02 Apr 2012 09:10 - 02 Apr 2012 11:01 #18912
by ArcEye
Replied by ArcEye on topic Re:rtapi_print_msg output
Hi
First off , always run linuxcnc from a terminal when developing, to ensure you trap all error messages etc.
It will depend upon what you have set the debugging level to.
If set to >= 3, rtapi_print_msg(RTAPI_MSG_INFO, ...) will display to Axis / stderr (can't remember which or if both)
However to set debugging too high would drive you mad with other debugging messages from the rest of the system.
Consequently I use rtapi_print_msg(RTAPI_MSG_ERR, " .........."); for debugging, even for none errors.
It displays to Axis and in the terminal.
Once finished I delete all the debug stuff and just leave actual error messages.
Last edit: 02 Apr 2012 11:01 by ArcEye.
- frequency
02 Apr 2012 09:59 #18913
by frequency
Replied by frequency on topic Re:rtapi_print_msg output
Ok,
but where can i set this debug level?
Many thanks,
Wolfgang
Many thanks,
Wolfgang
- ArcEye
02 Apr 2012 11:00 #18914
by ArcEye
Hi
In your .ini file under [EMC] section
DEBUG = 0
means no messages.
src/emc/nml_int/emcglb.h defines all the other values possible.
DEBUG = 0
means no messages.
- frequency
02 Apr 2012 12:41 #18920
by frequency
Perfect,
thank you!
thank you!
Time to create page: 0.055 seconds
