Questions about using comp
- billooms
12 Jul 2012 22:23 #21852
by billooms
Questions about using comp was created by billooms
I have several questions regarding the proper use of comp for compiling my own components. My component is called keypad.comp and the linesadded to my postgui.hal file are:
loadrt keypad count=1
addf keypad servo-thread
I have the source for linuxcnc downloaded and compiled in /usr/src/build/src. If I add my own component to hal/compoents, I can do a make and it compiles without errors. However, it isn't found when I launch linuxcnc:
keypad: dlopen: /usr/lib/linuxcnc/modules/keypad.so cannot open shared object file: No such file or directory
If I manually copy /usr/src/build/rtlib/keypad.so to /usr/lib/linuxcnc/modules it still is not loaded:
HAL: ERROR: function keypad not found
Also, if I try to keep the keypad.comp in my home directory (instead of copying it to the /usr/src/build/src/hal/components directory), the comp command is not found when I try to use it from the terminal. It exists in the /usr/src/build/bin/ directory and works if I type the full path name. Then in my own directory I do the following (based on HAL Manual V2.5 section 14.13):
/usr/src/build/bin/comp keypad.comp
/usr/src/build/bin/comp --compile keypad.comp
/usr/src/build/bin/comp --install keypad.comp
/usr/src/build/bin/comp --document keypad.comp
No errors, and the keypad.so is copied to /usr/src/build/rtlib but again the component does not load.
There's something obvious that I'm missing in all of this -- any help on what I'm missing?
- Thank you received: 4967
12 Jul 2012 22:30 #21854
Replied by andypugh on topic Re:Questions about using comp
billooms wrote:
The run-in-place one will be in linuxcnc-dev/scripts/rip-environment
You can probably also use . ./ linuxcnc-dev/scripts/linuxcnc to setup the environment and start linuxcnc.
My first guess would be the not-obvious requirement to run the correct environment script.There's something obvious that I'm missing in all of this -- any help on what I'm missing?
- billooms
12 Jul 2012 22:54 #21855
by billooms
Replied by billooms on topic Re:Questions about using comp
Thanks for the quick reply.
I did the rip-environment and now comp is recognized as it should be.
The command "comp --install keypad.comp" builds the .so file in /usr/src/build/rtlib/ but when I launch linuxcnc it still gives the message:
Apparently, linuxcnc is looking in /usr/lib/linuxcnc/modules and not looking in /usr/src/build/rtlib.
One more thing (maybe important, maybe not) -- I'm running simulation mode linuxcnc here in my office.
12 Jul 2012 23:02 #21857
billooms wrote:
Are you starting linuxcnc from the command line, or the GUI?
The GUI will (by default) use the installed version. After a rip-environment the command-line will use the rip-version.
I am surprised that comp doesn't work in the installed environment though. Did you "sudo" the comp --install?
There's little to be lost from copying the .so (actually, I would expect a .ko) from the linuxcnc-dev/src directory to /usr/src/build/rtlib
- ArcEye
- Thank you received: 758
13 Jul 2012 09:07 #21864
by ArcEye
Replied by ArcEye on topic Re:Questions about using comp
Hi
As Andy said, suspect you are executing linuxcnc outside the shell environment in which you ran . ./scripts/rip-environment
That first period (.) is crucial and means it persists only within the current shell session.
Even if you launched linuxcnc from the command line in another terminal, it would still default to the installed version.
- billooms
13 Jul 2012 18:40 #21913
by billooms
Andy -- No, I didn't sudo the comp --install. Without the sudo, it did successfully copy the .so to /usr/src/build/rtlib. When I do sudo it, I get the following:
sudo: comp: command not found
In a terminal window I change to directory /usr/src/build and execute the . ./scripts/rip-environment command (with the period). Then from that same terminal window I launch linuxcnc and it finds my component just fine! So I'm back in business for now!
Thank you for your help!
Time to create page: 0.229 seconds
