HAL component for the compumotor SX6 stepper drive
- Thank you received: 2160
04 Aug 2012 20:38 - 04 Aug 2012 20:40 #22809
HAL component for the compumotor SX6 stepper drive was created by cmorley
I built this component for the SX6 drive from Parker.
It communicates over RS232 using the serial port ( so it's a userspace program ).
It has constant velocity mode (for using it as a spindle drive) or indexing mode.
I tested it using a USB to serial converter which is very convenient.
The serial port is hardcoded which should be fixed.... and it's not really well tested or even finished...
Just wondering if anyone has one of these drives so something similar....
Last edit: 04 Aug 2012 20:40 by cmorley.
The following user(s) said Thank You: AlexN
04 Aug 2012 20:43 - 04 Aug 2012 20:43 #22810
Replied by cmorley on topic Re:HAL component for the compumotor SX6 stepper drive
It has an up-to-speed pin that doesn't quite work - if you go from a negative velocity to a positive velocity (or vice versa) the calculated time is wrong...
Last edit: 04 Aug 2012 20:43 by cmorley.
Time to create page: 0.047 seconds
