PID problem with 'D' in ver 2.5 & 2.5.1
  • joekline9
  • joekline9's Avatar Topic Author
  • Premium Member
  • Premium Member
21 Aug 2012 02:06 - 21 Aug 2012 02:06 #23455 by joekline9
PID problem with 'D' in ver 2.5 & 2.5.1 was created by joekline9
From joekline9. Joe Kline 8/20/2012
Hello,
I am new to forum so I hope I am putting this post in the proper place.
I recently converted two large servo driven milling machines from my old DOS based system to Linuxcnc 2.5 and 2.5.1
I have a desktop mill for testing, It is running Linuxcnc 2.4.
in Linuxcnc ver 2.5 & 2.5.1 the D in pid is not working.
It was ok in 2.4 but in 2.5 it is very flakey.
I found the problem in the source code.
component pid.c Line 353 needs to be like line 309 in ver 2.4
ver 2.4
line 309
/* calculate derivative term */
*(pid->error_d) = (tmp1 - pid->prev_error) * periodrecip;
pid->prev_error = tmp1;
/* apply derivative limits */
ver 2.5
line 353
/* and calculate derivative term as difference of derivatives */
*(pid->error_d) = *(pid->commandv) - *(pid->feedbackv);
Please inform me as to the correct way to rectify this problem.
Last edit: 21 Aug 2012 02:06 by joekline9.
21 Aug 2012 02:30 #23457 by PCW
Can you post your hal file?
21 Aug 2012 10:48 #23467 by BigJohnT
Replied by BigJohnT on topic Re:PID problem with 'D' in ver 2.5 & 2.5.1
Here is the description of that commit
Wed, 27 Oct 2010 09:37:24 -0500 (09:37 -0500)
One problem frequently identified with pid is that the D term is
excessively noisy due to quantization (particularly of feedback position).
Introduce command-deriv and feedback-deriv pins. These can be connected
to some (hopefully superior) source of the derivative. For example, a
system with an analog tach signal in hal could use that value for
feedback-deriv. It also becomes easier to test different derivative
computation functions, such as explicit smoothing of the D term or
the five-point method mentioned on wikipedia
en.wikipedia.org/wiki/Numerical_differen...Higher_order_methods
Zero, one, or both of the -deriv pins may be connected. When a -deriv
pin is not connected, the related value input is computed by the
traditional two-point difference method. This means that when neither
pin is connected the behavior is the same as before (except for rounding
differences).
21 Aug 2012 11:12 #23468 by andypugh
Replied by andypugh on topic Re:PID problem with 'D' in ver 2.5 & 2.5.1
When a -deriv pin is not connected, the related value input is computed by the traditional two-point difference method.
I seem to recall that Jepler did something a but cunning to work out if the pin was connected or not.
Perhaps that cleverness has been broken, or was never as clever as it looked?
21 Aug 2012 11:24 #23469 by BigJohnT
This is the diff... and it is beyond my level of cleverness.
-    /* calculate derivative term */
-    *(pid->error_d) = (tmp1 - pid->prev_error) * periodrecip;
+    /* compute command and feedback derivatives to dummysigs */
+    *(pid->commandvds) = (command - pid->prev_cmd) * periodrecip;
+    *(pid->feedbackvds) = (feedback - pid->prev_fb) * periodrecip;
+    /* and calculate derivative term as difference of derivatives */
+    *(pid->error_d) = *(pid->commandv) - *(pid->feedbackv);
21 Aug 2012 11:47 #23471 by andypugh
Some explanation here:
thread.gmane.org/gmane.linux.distributio...evel/3615/focus=3632
The derivative value calculated the old-fashioned way is written to a shared-memory address that he unconnected feedback-deriv pin was allocated when first created.
If that pin is netted to a signal in HAL then it will move to a different point in shared-memory. So the value will still be written to there, but not used.
21 Aug 2012 13:28 - 21 Aug 2012 13:30 #23474 by PCW
Can you please post your hal file?
Last edit: 21 Aug 2012 13:30 by PCW.
21 Aug 2012 13:52 #23476 by Todd Zuercher
Replied by Todd Zuercher on topic Re:PID problem with 'D' in ver 2.5 & 2.5.1
I believe the reason someone asked for you to post your Hal file is because, if you used PNConf to configure yours, there is/was a bug that caused it not to connect the velocity feedback pin correctly, essentially canseling out the D term.
21 Aug 2012 13:57 - 21 Aug 2012 13:59 #23477 by PCW
Yes theres that and the fact I just verified that the PID comp works correctly with both connected and unconnected feedback-deriv, at least with my 2.5.1 setup and hal file
Last edit: 21 Aug 2012 13:59 by PCW.
  • joekline9
  • Premium Member
  • Premium Member
21 Aug 2012 16:51 #23500 by joekline9
Replied by joekline9 on topic Re:PID problem with 'D' in ver 2.5 & 2.5.1
Here is one of my hal files. Originally created with pncconf in ver 2.5
File Name: HTS_Hillyer.hal
File Size:16 KB
Time to create page: 0.079 seconds
