PID problem with 'D' in ver 2.5 & 2.5.1
- joekline9
- Thank you received: 14
Hello,
I am new to forum so I hope I am putting this post in the proper place.
I recently converted two large servo driven milling machines from my old DOS based system to Linuxcnc 2.5 and 2.5.1
I have a desktop mill for testing, It is running Linuxcnc 2.4.
in Linuxcnc ver 2.5 & 2.5.1 the D in pid is not working.
It was ok in 2.4 but in 2.5 it is very flakey.
I found the problem in the source code.
component pid.c Line 353 needs to be like line 309 in ver 2.4
ver 2.4
line 309
/* calculate derivative term */
*(pid->error_d) = (tmp1 - pid->prev_error) * periodrecip;
pid->prev_error = tmp1;
/* apply derivative limits */
ver 2.5
line 353
/* and calculate derivative term as difference of derivatives */
*(pid->error_d) = *(pid->commandv) - *(pid->feedbackv);
Please inform me as to the correct way to rectify this problem.
- Thank you received: 5303
- BigJohnT
- Thank you received: 1177
Wed, 27 Oct 2010 09:37:24 -0500 (09:37 -0500)
One problem frequently identified with pid is that the D term is
excessively noisy due to quantization (particularly of feedback position).
Introduce command-deriv and feedback-deriv pins. These can be connected
to some (hopefully superior) source of the derivative. For example, a
system with an analog tach signal in hal could use that value for
feedback-deriv. It also becomes easier to test different derivative
computation functions, such as explicit smoothing of the D term or
the five-point method mentioned on wikipedia
en.wikipedia.org/wiki/Numerical_differen...Higher_order_methods
Zero, one, or both of the -deriv pins may be connected. When a -deriv
pin is not connected, the related value input is computed by the
traditional two-point difference method. This means that when neither
pin is connected the behavior is the same as before (except for rounding
differences).
- Thank you received: 5017
I seem to recall that Jepler did something a but cunning to work out if the pin was connected or not.When a -deriv pin is not connected, the related value input is computed by the traditional two-point difference method.
Perhaps that cleverness has been broken, or was never as clever as it looked?
- BigJohnT
- /* calculate derivative term */
- *(pid->error_d) = (tmp1 - pid->prev_error) * periodrecip;
+ /* compute command and feedback derivatives to dummysigs */
+ *(pid->commandvds) = (command - pid->prev_cmd) * periodrecip;
+ *(pid->feedbackvds) = (feedback - pid->prev_fb) * periodrecip;
+ /* and calculate derivative term as difference of derivatives */
+ *(pid->error_d) = *(pid->commandv) - *(pid->feedbackv);
thread.gmane.org/gmane.linux.distributio...evel/3615/focus=3632
The derivative value calculated the old-fashioned way is written to a shared-memory address that he unconnected feedback-deriv pin was allocated when first created.
If that pin is netted to a signal in HAL then it will move to a different point in shared-memory. So the value will still be written to there, but not used.
- Thank you received: 1467
- joekline9
