Integrate new driver to linuxCNC
- t1m0n
At the moment i use an own application (prog.c) which use a driver in userspace and a seperate library for communication with test boards over sercos.
These support functions for start bus communication, write and read. In prog.c I use only these functions for communication.
For example: I set an array:
array_OUT[4] = 255;
after write(); the testboard get this value and the LEDs on Byte4 are on.
But now, I want to use the PLC in LinuxCNC instead prog.c.
I want to set the array_OUT[4] from the PLC by wire diagramm.
What is the right way to integrate these functions for bus communication in LinuxCNC?
My idea is a driver-sercos.c which works like prog.c but the different is that there is a big list of variable declarations like:
array_IN[0] = plc_pin_0_in;
array_IN[1] = plc_pin_1_in;
array_IN[2] = plc_pin_2_in;
array_OUT[0] = plc_pin_0_out;
array_OUT[1] = plc_pin_1_out;
array_OUT[2] = plc_pin_2_out;
Then driver-sercos.c start communication and write the values. Thats my idea but I don't know how I can realise this.
- Thank you received: 4967
It probably helps to relise that a HAL "pin" is just an are of shared-memory that can contain one of the 4 types of data supported by HAL.Hi, I reat something about hal, halpins, hal components,.. but I don't understand how I can integrate a new driver.
When you link pins together in HAL all it means is that different blocks of code in different files access the same memory address, generally using a different variable name.
Are you sure you want to use the PLC (classic Ladder) for this, and not a realtime HAL component?But now, I want to use the PLC in LinuxCNC instead prog.c.
I think that even if you do want to use Classic Ladder you will need a Realtime HAL component too.
My idea is a driver-sercos.c which is like prog.c but there is a big list of variable declarations like:
I think what you want to do should be relatively easy using comp:
linuxcnc.org/docs/html/hal/comp.html
- t1m0n
The Classic Ladder was my first choice for a LinuxCNC Tool which I can use to get values from LinuxCNC.
I saw the examples and discreptions on linuxcnc.org/docs/html/hal/comp.html but these are not very helpfull.
I think the best is "14.3. out8" but all of these are not helpfull for my problem.
There are two parts to it, a realtime part and a userspace part. I don't know a lot more about it than that, thoughIs Classic Ladder no realtime component?
I am more used to C, so write custom HAL components when needed.
I admit I am not entirely sure what your problem is.I think the best is "14.3. out8" but all of these are not helpfull for my problem.
I think you should be able to put your existing code in the code section of a comp, add a bunch of pins at the top, and use it in HAL.
However, your description of the architecture is still a bit sketchy.
I think that Sercos / LinuxCNC might already be a solved problem.
www.bitmuster.org/projects/emc.html
- t1m0n
But I use a special card which is able to change the bus system by some modifications.
Later, I want to use different bus systems. Then there is no different between sercos, ethercat or profibus because this is the job of the hardware and firmware, not HAL.
Let's assume I do this with comp.
I have to understand one example
The way is to write a programm in c and then modify it for comp.
The example: 14.2. sincos:
component sincos;
pin out float sin_;
pin out float cos_;
pin in float theta;
function _;
license "GPLv2 or later";
#include <rtapi_math.h>
FUNCTION(_) { sin_ = sin(theta); cos_ = cos(theta); }
sin(theta): This is a c-function, right? Where is theta defined?
The FUNCTION(_) is there because this it is required for comp that it knows there is a c-function?
sin_: this is the name of the variable inside this driver and outside sincos.<num>.sin?
How I can set this variable from PLC- or is it known in LinuxCNC (i.e. Classic Ladder) during the declaration pin out float sin_; ?
What can I do with <num>? In
The last question: why rtapi_math.h instead of math.h ?
In the pin in float theta line.pin in float theta;
It might be helpful to look at the generated C-code that comp creates, you will see that "theta" gets macro-substituted to something like inst[n]->theta
That is another macro-substitution in the generated C, the function name and the parameters that need to be passed to each instance.The FUNCTION(_) is there because this it is required for comp that it knows there is a c-function?
Part of what comp does is deal with the complexity of the possibility of there being very many instances of each component loaded, all of which need an independent internal state.
Yes, it's a pin name, and also a variable name inside the C code section. Writing a value to sin_ in the C-code will put that value on the HAL pin for other components to use. The trailing _ is to differentiate from the built-in function but is removed when naming the HAL pin.sin_: this is the name of the variable inside this driver and outside sincos.<num>.sin?
[quoteHow I can set this variable from PLC[/quote]You can't. it's an Output pin from the HAL component. You could read it into a Classic Ladder system, by a net command in the HAL file that connected the comp output to one of the Ladder inputs.
rtapi_math defines a set of thread-safe mathematical functions guaranteed to work in realtime.why rtapi_math.h instead of math.h ?
I have a feeling that you are missing something fundamental about HAL, but I am not sure what it is so can't clear it up.
- t1m0n
rtapi_math defines a set of thread-safe mathematical functions guaranteed to work in realtime. [/quote]why rtapi_math.h instead of math.h ?
I think this will be my next problem because I want to use RT_PREEMPT instead of rtai to realize realtime. This is nessecary because the required driver and library don't use rtai_libs.
Yes, thats feeling is right ;( but I want to understand it.I have a feeling that you are missing something fundamental about HAL, but I am not sure what it is so can't clear it up.
summary:
I want to use C-Code in linuxcnc
but you say that it is easier to generate a C-Code with Comp HAL Component Generator
With RT_PREEMPT it is possible to use userspace in realtime.
Than I can use chapter 13: linuxcnc.org/docs/html/hal/comp.html#_co...side_the_source_tree
But this only works for .comp files, not for .c files.
My sourcecode (*.c-Files) consists of 500 lines sourcecode. When I modified it to a comp-File and compiled it. The sourcecode is much bigger?
I use special-functions from a library which is from the customer of my hardware. Does the comp-compiler know where the library is? (gcc knows it because I compile with a big make-file).
- ArcEye
- Thank you received: 758
Yeah, comp does bloat the binary, I only use it to compile actual .comp files, although you can use it for more.My sourcecode (*.c-Files) consists of 500 lines sourcecode. When I modified it to a comp-File and compiled it. The sourcecode is much bigger?
comp has no idea what special libraries you need.I use special-functions from a library which is from the customer of my hardware. Does the comp-compiler know where the library is? (gcc knows it because I compile with a big make-file).
If I want to link against a particular library, I normally just cut and paste the build string from comp that just failed ( because of unresolved references that are in the library ).
Then I add in a -L/address/of/library and -lmylibrary to the string and run that instead of comp, quicker than editing comp or writing a new makefile
- ArcEye
I forgot I actually have a script set up to do this, amongst many other things, called proIf I want to link against a particular library, I normally just cut and paste the build string from comp that just failed ( because of unresolved references that are in the library ).
The relevant fragment is
# !/bin/bash
case $1 in
help) cat /pro | less;;
comp ) comp $2.comp
gcc -Os -g -I. -I/usr/realtime-2.6.32-122-rtai/include -I. -I/usr/realtime-2.6.32-122-rtai/include -D_FORTIFY_SOURCE=0 \
-mhard-float -DRTAI=3 -fno-fast-math -mieee-fp -fno-unsafe-math-optimizations -DRTAPI -D_GNU_SOURCE -Drealtime\
-D_FORTIFY_SOURCE=0 -D__MODULE__ -I/usr/include/emc2 -Wframe-larger-than=2560 -URTAPI -U__MODULE__ -DULAPI -Os \
-o $2 $2.c -Wl,-rpath,/lib -L/lib -lemchal -l$3;;
esac
So pro comp myfile special_lib
will produce a C file from myfile.comp then compile myfile.c, outputting the binary myfile which is additionally linked against special_lib
NB There are of course bash 'end of line' \ chars in this, but the forum does funny things to lots of special characters, it thinks are escape sequences
Hopefully I have managed to put them back again by double 's
I think this will be my next problem because I want to use RT_PREEMPT instead of rtai to realize realtime. This is nessecary because the required driver and library don't use rtai_libs.[/quote]Note that it is rtapi_math, not rtai_math.
rtapi tries to create a common interface for rt-linux and rtai. I think (but I am not sure) that it also does the same for rt-preempt.
Are you sure about that? I haven't looked at rt-preempt, but I would be surprised if you could simply run normal code as realtime code. Most realtime code is written to run to completion every time the thread it is running in is polled (every module linked to the servo thread, for example, is run in sequence every millisecond. The means no wait-loops in the code, or the whole machine stops dead.With RT_PREEMPT it is possible to use userspace in realtime.
You can use #include in the C-code part of a comp to link to external files, or the "include" instruction in the part above the ;; sequence if it is important that the types be included during the pin definition phase. (it might help to look at the intermediate C-code to see why this matters).I use special-functions from a library which is from the customer of my hardware. Does the comp-compiler know where the library is? (gcc knows it because I compile with a big make-file).
Note that when the C-code is compiled it isn't in the same place as the .comp file. Another reason to comp into intermediate C first is to see where the files are put before being passed to the compiler in order to work out how to set up relative include paths. (This really could do with a proper fix)
