Problems with gearchange component
  • hardware_crash
  • hardware_crash's Avatar Topic Author
  • Premium Member
  • Premium Member
06 Sep 2012 12:26 - 06 Sep 2012 12:29 #23969 by hardware_crash
Problems with gearchange component was created by hardware_crash
Hey guys,
I wrote a little comp for a 9 gear gearswitch.
But it doesnt work as it should and i dont know if there is a possibility to check if the programm runs correctly ...
I have installed the "DEV" package and installed the comp with "comp --install gearswitch.comp " and there were no errors...
Is there a way to view the comp like in classicladder , where the active signals have a different color ?
Or any other way to see that the error is not in the programm ?
I connected the outputs of gearswitch.comp with the hal outputs like this :
net backGearMotor gearswitch.gearBitOUTBackGear => hm2_[HOSTMOT2](BOARD).0.gpio.081.out
is this correct?
I have attached the comp file, maybe I did something wrong...
best regards
Lukas
File Name: gearswitch.comp
File Size:11 KB
Last edit: 06 Sep 2012 12:29 by hardware_crash.
06 Sep 2012 12:33 #23973 by andypugh
Replied by andypugh on topic Re:Problems with gearchange component
I am nowhere near my LinuxCNC machines at the moment, so can't check the component.
One thing I will suggest is making the state flag into an output pin, so you can monitor progress through the comp with halscope.
Silly question, but did you remember to addf the component to a thread, and start the thread?
  • hardware_crash
  • Premium Member
  • Premium Member
06 Sep 2012 12:50 #23974 by hardware_crash
Replied by hardware_crash on topic Re:Problems with gearchange component
dear andy,
Yes i added it to the servo thread ..
maybe there is a problem when linking the comp files outputs direct to the mesa io pins ?
:dry:
06 Sep 2012 13:55 #23977 by andypugh
No, that should be perfectly OK. How else would you do it?
  • hardware_crash
  • Premium Member
  • Premium Member
06 Sep 2012 14:30 #23981 by hardware_crash
Don´t know i was just thinking :laugh:
  • hardware_crash
  • Premium Member
  • Premium Member
06 Sep 2012 20:53 #23988 by hardware_crash
Seems like there is an error while calling the part which sets the Motor to the sellected position:
static char GearSwitchSetBackGear(int gear, char setup) {
switch (gear) {
case 1: if ((gearBitINBackGearLeft) == TRUE) { // no matter wether it is setup or not
gearBitOUTBackGear = FALSE; // switch off motor
return TRUE;
if (setup) {
gearBitOUTReverse = FALSE; // Richtung des Motor
gearBitOUTBackGear = TRUE; // Motor einschalten
return FALSE; // Warten auf den Enschalter bis er TRUE wird
case 2: if (gearBitINBackGearCenter) { // Egal ob Setup gesetzt oder nicht , bei erreichen d. Enschalters abschalten
gearBitOUTBackGear = FALSE; // Motor ausschalten
return TRUE;
if (setup) {
if (gearBitINBackGearLeft){
gearBitOUTReverse = TRUE; // Richtung des Motor
if (gearBitINBackGearRight){
gearBitOUTReverse = FALSE; // Richtung des Motors
case 3: if (gearBitINBackGearRight) { // Egal ob Setup gesetzt oder nicht , bei erreichen d. Enschalters abschalten
return TRUE;
if (setup) {
// fall through
default:
I get the error "Fault with vec=14...."
Anybody an idea ?
06 Sep 2012 21:15 #23989 by andypugh
You may be using an unintialised pointer, or writing outside the bounds of an array.
It's hard to debug realtime code, especially using comp.
First it is probably worth looking at the intermediate C code that comp creates with no options.
The most likely problem is that you are using a variable name that is also used internally in the intermediate C. The most likely candidate is "setup". Try a different name for that variable.
  • hardware_crash
  • Premium Member
  • Premium Member
06 Sep 2012 21:34 - 06 Sep 2012 21:36 #23991 by hardware_crash
hey andy,
I have read that the comp acesses the pins via macros and there has to be the pointer for the macro ? is this correct ?
maybe there is my fault ?
Is there anybody who can test my comp ??
best regards
lukas
Last edit: 06 Sep 2012 21:36 by hardware_crash.
06 Sep 2012 21:49 #23993 by andypugh
Not quite. comp "macro substitutes" all the pin names, so that if you have
pin in bit bitpin
then there is a #define in the generated C something like
#define bitpin inst->bitpin[0]
(or something like that)
The problems come if you define a pin with the same name as one of the "internal" variables. "inst" is particularly bad.
If I was debugging your module (and I can't , I am working in Spain, and my computers are in the UK) then I would compile it the source with make, so that I could use
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...fs/heads/v2.5_branch
I think you need to look at the generated C and see if any variables get re-used, or any other semi-obvious problems.
  • hardware_crash
  • Premium Member
  • Premium Member
07 Sep 2012 11:58 - 07 Sep 2012 12:01 #24011 by hardware_crash
hey andy,
I tried this git.linuxcnc.org/gitweb?p=linuxcnc.git;a...fs/heads/v2.5_branch
But i can´t find the "fault.ko" module in the module directory or in any other place on the system ..
Do you know another way to see the faulty programm parts ?
BR,
Lukas
Ps i attached the compile gearswitch programm ...
File Size:18 KB
Last edit: 07 Sep 2012 12:01 by hardware_crash.
