The simple impulse generator
- aike
- Thank you received: 4
16 Oct 2012 12:20 #25370
by aike
The simple impulse generator was created by aike
Hi!
I need to create simple impulse generator, frequency 10Hz, impilse width about 20mS.
What is the best HAL componet for this?
The generator has to operate the hole time of working CNC. (From switch on till switch off).
- BigJohnT
- Thank you received: 1176
16 Oct 2012 12:30 #25371
by BigJohnT
Replied by BigJohnT on topic Re:The simple impulse generator
- aike
16 Oct 2012 12:32 #25372
by aike
Replied by aike on topic Re:The simple impulse generator
Thank you, it is sutable case for me.
- Thank you received: 4968
16 Oct 2012 15:05 #25377
Replied by andypugh on topic Re:The simple impulse generator
aike wrote:
pwmgen would work too. You could run it in the servo thread for that sort of rate.
Set pwm frequency to 10Hz and duty cycle to 0.02.
Time to create page: 0.052 seconds
