Need Help finishing setup of Logitech joystick
- jalbers
14 Dec 2012 22:00 #27729
by jalbers
Need Help finishing setup of Logitech joystick was created by jalbers
I have a Probotix Fireball V90 and want to use a Logitech USB joystick to control the machine. This is a breakdown of what I have done so far:
Plug In Joystick
Directory: /proc/bus/input
Look at File: devices
Partial Contents:
Bus=0003 Vendor=046d Product=c216 Version=0110
Name="Logitech Logitech Dual Action"
Directory: /etc/udev/rules.d
Created File: logitech.rules
Contents:
SYSFS{idProduct}=="c216",SYSFS{idVendor}=="046d",MODE="0660",GROUP="plugdev"
Directory: ~/linuxcnc/configs/V90
Created File: logitech.hal
Contents:
loadusr -W hal_input -KRAL Logitech
Directory: ~/linuxcnc/config/V90
Edit File: V90.ini
Partial Contents:
[HAL]
HALFILE = V90.hal
HALFILE= custom.hal
HALFILE = logitech.hal
POSTGUI_HALFILE = custom_postgui.hal
Unplug Joystick
Plug Joystick In
Start Hal Meter
Test Pin: input.0.btn-base
Returns: TRUE/FALSE
Test Pin: input.0.abs-x-position
Returns: Values a range of values between -1 and +1
Test Pin: input.0.abs-hat0x-position
Returns: -1,0,+1
The joystick appears to be working!
*** THIS IS WHERE I NEED HELP ***
I do not know what to do next to get the joystick to talk to the Axis GUI.
What needs to be done to make input.0.btn-base turn on and off the spindle for example?
What needs to be done to make input.0.abs-x-position jog the x-axis to the left or right at different speeds depending on how far left or right the joystick is moved?
What needs to be done to make input.0.abs-hat0x-position jog the x-axis to the left or right?
Any help would be greatly appreciated. Thanks
Plug In Joystick
Partial Contents:
Contents:
Contents:
Edit File: V90.ini
Partial Contents:
[HAL]
HALFILE = V90.hal
HALFILE= custom.hal
Unplug Joystick
Plug Joystick In
Start Hal Meter
Returns: TRUE/FALSE
Returns: -1,0,+1
- Rick G
- Thank you received: 155
14 Dec 2012 22:10 #27730
by Rick G
Replied by Rick G on topic Need Help finishing setup of Logitech joystick
Have you looked here?
wiki.linuxcnc.org/cgi-bin/wiki.pl?Simple_Remote_Pendant
and
wiki.linuxcnc.org/cgi-bin/wiki.pl?Adding...imple_Remote_Pendant
Rick G
and
Rick G
- BigJohnT
- Thank you received: 1176
14 Dec 2012 23:02 #27732
by BigJohnT
In addition to the Rick's links...
You might want to cruise the Hal Examples here is an example of start/stop button connections in hal.
Also you will want to read the Hal Basic Tutorial .
Replied by BigJohnT on topic Need Help finishing setup of Logitech joystick
Time to create page: 0.055 seconds
