Hal for control of analog output of 5i25 nd 7i76
22 Dec 2012 07:22 #27938 by diegoroman17
Hi everybody,
I am migrate from my antique 7i78 card to 7i76 because I need more GPIO pins in my CNC Laser. But my surprise that it give a error that say don´t exist pwm component in this configuration. I try use PncConf but doesn´t exist any configuration for PWM or analog channel. How can I configurate the analog output in the hal file?
22 Dec 2012 08:44 - 22 Dec 2012 08:59 #27941 by PCW
The single analog output on the 7I76 is called
spinout (short for spindle output)
in addition there are spinena and spindir (enable and direction)
A good way to see what pins are available is to start linuxcnc with a minimal
HAL file that will start with no assumptions about available pins
and then run
halcmd show pin > mypins
in a terminal
(you can do parameters similarly)
Last edit: 22 Dec 2012 08:59 by PCW. Reason: ommision
22 Dec 2012 10:19 #27949 by andypugh
and then run halcmd show pin > mypins
With the 5i25 you don't even need a HAL file for the default config:
halrun
loadrt hostmot2
loadrt hm2_pci
show all
24 Dec 2012 22:57 #28003 by diegoroman17
Replied by diegoroman17 on topic Hal for control of analog output of 5i25 nd 7i76
halrun
loadrt hostmot2
loadrt hm2_pci
show all
I try it but don't found the spinout pin or spinena or spindir why?
24 Dec 2012 23:15 #28004 by PCW
pin names would be:
hm2_5i25.0.7i76.0.0.spinout
hm2_5i25.0.7i76.0.0.spindir
hm2_5i25.0.7i76.0.0.spinena
if you dont see these (or the 80 or so other pins with 7i76 in their names)
its most likely that you dont have field I/O power supplied to the 7I76
24 Dec 2012 23:33 #28006 by diegoroman17
Why Is absolutely necessary connect field power to see this pins? Can you explain me please?
24 Dec 2012 23:47 - 24 Dec 2012 23:49 #28007 by PCW
Because the capability of the remote I/O is
unknown by LinuxCNC until communication is established
and the remote I/O runs on field power so cannot communicate
if field power is not present.
Last edit: 24 Dec 2012 23:49 by PCW.
The following user(s) said Thank You: diegoroman17
25 Dec 2012 00:00 #28009 by diegoroman17
Now I understand. The spindle signals is into field signals and it communicate with 5i25 with a field protocol and it aren't active while does not exist field power supply. Thanks now I can see the pins
25 Dec 2012 00:03 #28010 by PCW
Its seems funny but its a great advantage for flexibility,
For example if we add a firmware option to the remote I/O
(or a new remote I/O card) the pins appear to HAL automatically
without any other changes in linuxCNC required
Time to create page: 0.081 seconds
