Saving parameters after shut down
13 years 5 months ago - 13 years 5 months ago #33995 by ArcEye
Yes I know all about that. I started that thread.
Oops :blush: Mind like a sieve, I spent the last 2/3rds of the thread talking to Big Alex and had forgotten it was your request originally.
Glad you are finding it useful, after original reservations I am glad I did it too, have used it a couple of times already.
Last edit: 13 years 5 months ago by ArcEye.
13 years 5 months ago #34011 by mariusl
Hey, cant blame you. So many things at the same time and a whole lot of moaning users taboo. :)
The pyvcp is now just what the layman needed to make it more usable. I think one can get very creative with labels to make the GUI more friendly.
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #34025 by mariusl
ArcEye, cant get this parameter file of yours to work. It compiles happily but does bugger all further. I cant seem to get any data from any of the pins. Even if I hard code it. It seems that it does not fall into the while loop. Maybe something with the signal stuff?
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #34026 by ArcEye
Hi
I didn't realise that was what you were using, it was just a back of an envelope demo of what I was speaking about.
I said at the time I had not tested it (albeit I had used something similar before)
Let me know how many pins of what type (bit, s32, float) you want to connect to and read / write and I will look at it tomorrow
13 years 5 months ago #34031 by mariusl
ArcEye
I realized it was just a demo. It was the closest thing that I could find that would do what I wanted, Well almost.
I am looking at saving and retrieving three floats. Basically three spin box settings for the THC. velocity_tolerance, volt_setting and volt_tolerance.
Regards
Marius
www.bluearccnc.com
13 years 5 months ago #34036 by andypugh
mariusl wrote: I am looking at saving and retrieving three floats. Basically three spin box settings for the THC. velocity_tolerance, volt_setting and volt_tolerance.
This becomes automatic with an on_destroy option set up in GladeVCP.
If you look in this thread: www.linuxcnc.org/index.php/english/forum...ility?start=40#33860
There is a panel already set up with three spinboxes that retain values on shut-down. You could just change the labels.
Time to create page: 0.327 seconds
