- Thank you received: 31
ArcEye wrote: One easy way to side step the problems of accessing devices from a realtime module, would be to write a userspace component whose sole function is to read parameters at start up and write them to disc when signalled at close down.
You could then just connect the userspace to the realtime component, via suitable HAL pins for your data type, and have a signal pin to trigger a read or write.
How would one signal the file to read or write at close down or startup?
