Changing mux2.0.sel values every X time.
- casetero
05 Feb 2013 18:39 #29632
by casetero
Replied by casetero on topic Changing mux2.0.sel values every X time.
Andy it works great!!
As curiosity see this URL:
gnipsel.com/shop/hardinge/files/mpg.xhtml
This code shows esactly the same factor scale, 40. Really in my machine 40 is not the real factor scale, is about 40.8 and it changes if raw-val is sending 1 or 2 or 3 ( due to the angular velocity you make at the jog wheel)
But it doesn´t matter, it is super precise and you can get zeros with much precision.
If you come to Spain sometime, Alicante city for more precision you are invited to a Paella, that´s for sure!
Now i´m going to make the whole code for the buttons and velocitys and so.
But don´t forgive me, as said yesterday LCD battle is waiting us...
Thank you very much Andy!!
- Thank you received: 4968
05 Feb 2013 20:00 #29638
OK, that's excellent.
The clever thing to do now is probably to put that code inside your version of the shuttlexpress component, along with whatever other code is needed to turn the button raw values into individual HAL bits.
Replied by andypugh on topic Changing mux2.0.sel values every X time.
- casetero
06 Feb 2013 00:34 #29650
by casetero
Andy i´ve been trying to descifrate shuttlexpress.c and i think it doesn´t manage with LCD. I have seen nothing about LCD outputs.
I´ve been reading the manpage of Hidcomp, and have added this lines to /usr/share/linuxcnc/linuxcnc.nml
P hidcomp emcCommand LOCAL localhost W 0 10.0 0 10
P hidcomp emcStatus LOCAL localhost R 0 10.0 0 10
P hidcomp emcError LOCAL localhost R 0 10.0 0 10
and to my ini file this one:
[EMC]
NML_FILE = /usr/share/linuxcnc/linuxcnc.nml
But hidcomp continues not showing outputs for the LCD.
Am i doing something wrong??
Can i use another component or code to try to enhace the LCD??
Another strange thing is that when hidcomp is runed with the device enhaced, his hidraw file disappears and shuttlexpress can´t find it.
Thank you!
[EMC]
Thank you!
06 Feb 2013 01:03 #29653
However, it looks like the hidconfig application would be useful, have you tried that?
hidcomp.sourceforge.net
It might also be useful to start hidcomp in debug mode (-d switch) and see what info can be found in the dmesg output.
www.linuxcnc.org/docs/html/man/man1/hal_input.1.html
I really have no idea, I have never used hidcomp.Am i doing something wrong??
It would be interesting to see what hal_input does with the device.Can i use another component or code to try to enhance the LCD??
- casetero
06 Feb 2013 04:50 #29670
by casetero
Yes, i configure the device outputs of the device with hidconfig. But it doesn't show any input to the device.
With hal_input i cant enhace the device. I don't know why, but when i put in a terminal less / less /proc/bus/input/devices it doesn't show the device, but if i put lsusb it does show.
Maybe this can be a good symptom of what happens with hal_input.
I have seen this component created by you:
www.linuxcnc.org/docs/html/man/man9/lcd.9.html
Can be suitable for me?
Thank you!
Thank you!
06 Feb 2013 15:02 #29688
I suspect that the lcd.comp won't be any help to you, unfortunately. That sends a character every mS in a realtime thread. I don't think that would be compatible with a userspace driver like hidcomp or hal_input.
The _contents_ of the component might be usable, but as the main thing it does is create kernel-mode versions of the printf function for use with floating-point values even that is of dubious value.
- casetero
09 Sep 2013 19:59 #38565
by casetero
Resqueing old posts...
Andy as now i have the comp --compile and --install available ( installing the dev-package) I tried to recompile the component you made called wheel.comp:
component wheel "pendant jogwheel thingy";
pin in signed raw-val;
pin out signed jog-counts;
function _;
author "andy pugh";
license "GPL";
FUNCTION(_){
char v;
v=raw_val;
jog_counts += v;
I tried to make another wheel2.comp just changing this:
function _;
author "andy pugh";
license "GPL";
FUNCTION(_){
int v; <
The change
v=raw_val;
jog_counts += v;
And it seems to be incompatible with wheel.comp. It cant load the two components at the same time. Do you know why??
Thank you.
function _;
author "andy pugh";
license "GPL";
FUNCTION(_){
char v;
v=raw_val;
jog_counts += v;
function _;
author "andy pugh";
license "GPL";
FUNCTION(_){
int v; <
The change
v=raw_val;
jog_counts += v;
Thank you.
09 Sep 2013 20:14 #38567
The HAL name of the component is not based on the file name but on the "compoenent" line at the top of the .comp file.
In fact things break in interesting ways if the file name and the "component" name do not match. If you make sure that the component name and file name do match, and are different for the two components, then it should all be OK.
And it seems to be incompatible with wheel.comp. It cant load the two components at the same time. Do you know why??.
The following user(s) said Thank You: casetero
- casetero
09 Sep 2013 20:18 #38568
by casetero
Ok
That was the problem.
Thank you.
Thank you.
Time to create page: 0.073 seconds
