G code HAL detect
- diegoroman17
11 Apr 2013 21:01 #32566
by diegoroman17
G code HAL detect was created by diegoroman17
Hi everybody,
I need detect in hal the actual Gcode that is running, if it is G0 or not. Is possible do it?
- ArcEye
- Thank you received: 758
11 Apr 2013 22:20 #32573
by ArcEye
Replied by ArcEye on topic G code HAL detect
Hi
It is quite difficult to ascertain exactly which line of the G Code is being executed
There is no way to do it in HAL AFAIK
In C something like
but it is often difficult still to get accurate updating of the current line
You can fetch the active GCodes, but you are dependent upon the speed of updating etc as to whether they are accurate
(a short G00 line surrounded by G01 lines might show fleetingly after that line is executed, if the move is very short)
To get it more accurately, you may need to hook into the interpreter, depends exactly what you are trying to do
In C something like
if (programStartLineLast < 0 || emcStatus->task.readLine < programStartLineLast)
// controller is skipping lines
programActiveLine = emcStatus->task.readLine;
else
// controller is not skipping lines
if (emcStatus->task.currentLine > 0)
if (emcStatus->task.motionLine > 0 && emcStatus->task.motionLine < emcStatus->task.currentLine)
programActiveLine = emcStatus->task.motionLine;
else
programActiveLine = emcStatus->task.currentLine;
else
programActiveLine = 0;
QString getActiveGCodes()
int code;
char string[80];
QString active_g_codes;
active_g_codes.clear();
string[0] = 0;
for (int t = 1; t < ACTIVE_G_CODES; t++).
code = emcStatus->task.activeGCodes[t];
if (code == -1)
continue;
if (code % 10).
sprintf(string, "G%.1f ", (double) code / 10.0);
else
sprintf(string, "G%d ", code / 10);
active_g_codes += string;
return active_g_codes;
- diegoroman17
11 Apr 2013 22:47 #32574
by diegoroman17
Replied by diegoroman17 on topic G code HAL detect
mmm This is quite difficult. It occurred to me a better solution. I will use a digital output before G0 in G code tell me if it runs or not G0.
- ArcEye
11 Apr 2013 23:12 #32576
by ArcEye
If you are only going to be executing your own code, that is a lot easier
- diegoroman17
11 Apr 2013 23:14 #32577
by diegoroman17
jjj yeah. I have develop a sofware CAM into Corel Draw for generate my own G Code. Thanks for help me ArcEye
Time to create page: 0.124 seconds
