Timed exit while loop. Best way?
- DaOne
- Thank you received: 6
04 Jun 2013 04:18 #35229
by DaOne
Timed exit while loop. Best way? was created by DaOne
I would like to have a timed exit in a while loop for my hal tool changer component. I am waiting for an input in a loop and if I don't get it in a few seconds I want it to alarm out with a message. I am wondering the best way to achieve this. Probably a stupid question but I am still a newbie to LinuxCNC.
- BigJohnT
- Thank you received: 1175
04 Jun 2013 04:48 - 04 Jun 2013 04:49 #35231
by BigJohnT
Replied by BigJohnT on topic Timed exit while loop. Best way?
The easy way to do a tool changer is with
classicladder
. My Hardinge CHNC configuration files are
here
JT
JT
Last edit: 04 Jun 2013 04:49 by BigJohnT.
- willburrrr2003
04 Jun 2013 04:48 #35232
by willburrrr2003
Replied by willburrrr2003 on topic Timed exit while loop. Best way?
I would use classicladder to handle the timing and alarm logic for this.
Regards,
Will
Regards,
Will
- DaOne
04 Jun 2013 04:59 #35233
by DaOne
Replied by DaOne on topic Timed exit while loop. Best way?
Is there a benefit to using classicladder? I am OK with C for the most part. I am not a coder by any means however.
I am working on a Hitachi Seiki 3NE-300
My turret sequence....
1)Tool change command given
2)Turret unclamped. (SOL 7 ON)
3)Turret checked to make sure its unclamped. (Limit switch 14 OFF)
4)Hydraulic motor turned on full speed to rotate the turret. (SOL 9 ON)
5)Truth table is read to determine correct tool position for commanded tool.(Limit switches 15-18)
6)Wait for rough alignment cam to switch. (limit switch 19 ON)
7)Slow turret while rough index pin is advanced. (SOL 8 ON)
8)Wait for alignment cam to switch. (limit switch 20 ON)
9)Clamp turret. (SOL 7 OFF)
10)Stop hydraulic motor. (SOL 9 OFF)
11)Check to make sure the turret is clamped (Limit switch 14 ON)
12)Rough index pin is retracted. (SOL 8 OFF)
13)Tool has been changed command returned.
My truth table is...
I was basing off the oracchanger.comp here
Tool| 1| 2| 3| 4| 5| 6| 7| 8| 9|10|11|12|
LS15| X| X| | | X| X| X| X| | | X| X|
LS16| | X| X| X| X| | | X| X| X| X| |
LS17| | | | X| X| X| X| X| X| | | |
LS18| | | | | | | X| X| X| X| X| X|
X= ON
- DaOne
04 Jun 2013 05:42 #35235
by DaOne
BigJohnT, whats the best way to run your Hardinge setup without having that card? I have a 5i25 paired with a 7i77 and am still a newbie in this hal setup stuff. When I try to run your files without the hardware I get errors because the hardware isn't found. Thanks in advance.
-Wes
-Wes
- BigJohnT
04 Jun 2013 05:50 #35236
by BigJohnT
Open a sample configuration with classicladder or create one with stepconf wizard and open the ladder editor. The open my harding.clp file to view it.
JT
JT
- BigJohnT
04 Jun 2013 05:52 #35237
by BigJohnT
I also have a
sample config
to show how classicladder works with a tool changer on my web site.
- DaOne
04 Jun 2013 05:59 #35238
by DaOne
BigJohn, Not sure where on your site the harding.clp file is? I downloaded the EMC2 CHNC Config Files and that file is not in there. Maybe I am looking in the wrong place?
- DaOne
04 Jun 2013 07:00 #35240
by DaOne
- DaOne
04 Jun 2013 07:03 - 04 Jun 2013 07:04 #35241
by DaOne
Ok, I am looking at the classic ladder. About the only part I can't wrap my head around is the truth table. Maybe someone can translate?
if(tts1 && !tts2 && !tts3 && !tts4)
position = 1;
else if(tts1 && tts2 && !tts3 && !tts4)
position = 2;
else if(!tts1 && tts2 && !tts3 && !tts4)
position = 3;
else if(!tts1 && tts2 && tts3 && !tts4)
position = 4;
else if(tts1 && tts2 && tts3 && !tts4)
position = 5;
else if(tts1 && !tts2 && tts3 && !tts4)
position = 6;
else if(tts1 && !tts2 && tts3 && tts4)
position = 7;
else if(tts1 && tts2 && tts3 && tts4)
position = 8;
else if(!tts1 && tts2 && tts3 && tts4)
position = 9;
else if(!tts1 && tts2 && !tts3 && tts4)
position = 10;
else if(tts1 && tts2 && !tts3 && tts4)
position = 11;
else if(tts1 && !tts2 && !tts3 && tts4)
position = 12;
else
position = 0;
Last edit: 04 Jun 2013 07:04 by DaOne.
Time to create page: 0.286 seconds
