Timed exit while loop. Best way?
- BigJohnT
- Thank you received: 1176
04 Jun 2013 07:06 #35242
by BigJohnT
Here is the link
gnipsel.com/linuxcnc/examples/cl-turret.zip
JT
Replied by BigJohnT on topic Timed exit while loop. Best way?
BigJohn, Not sure where on your site the harding.clp file is? I downloaded the EMC2 CHNC Config Files and that file is not in there. Maybe I am looking in the wrong place?
Here is the link
JT
- BigJohnT
04 Jun 2013 07:07 #35243
by BigJohnT
That's not the one I linked to...
JT
Found it here...
linuxcnc.org/dapper/emc2/index.php/russi...ssic-ladder?start=10
JT
- BigJohnT
04 Jun 2013 07:10 #35244
by BigJohnT
- DaOne
- Thank you received: 6
04 Jun 2013 07:21 #35245
by DaOne
Replied by DaOne on topic Timed exit while loop. Best way?
John, I was referring to the
hardinge.clp
file as it is not in your "EMC2 CHNC Config Files" that you down load from your website.
This weighted sum component sounds a bit over my head. LinuxCNC has been a steep learning curve for me coming from Windows and Mach 3. My last lathe was a stepper driven machine. I am wondering if I wouldn't be better off with my original way? Maybe you could help me understand weighted sum components with some sort of example?
- ArcEye
- Thank you received: 758
04 Jun 2013 16:41 #35249
by ArcEye
Replied by ArcEye on topic Timed exit while loop. Best way?
Hi
I you want to use C (that is what I am most comfortable with too) look at the Orac Toolchanger I wrote.
wiki.linuxcnc.org/cgi-bin/wiki.pl?Contri...oolchanger_component
That uses a greyscale encoder truth table and has delays built in to allow mechanical movements, both by linkage to the timedelay component and an internal timer.
The big thing about realtime components is how quickly they are polled, so the program needs to do a bit and then return.
while() loops are a very bad idea full stop and I never use them.
The alternative is to use a state change, switch loop, where a progress level is set and each time the component is polled it goes to that level, does or checks something and returns.
When the required value is reached or whatever, the progress level is changed to move to the next task.
Regards an internal timer can be as simple as
The component just increments a timer and returns until the required value is reached and then moves to the next level, to do the next part of the toolchange.
Might give you some ideas
case 1: // programmed delay to allow relays time to change over
if(sleeptime < times)
sleeptime++;
break;
run = true;
progress_level = 2;
break;
- BigJohnT
04 Jun 2013 19:14 #35253
by BigJohnT
I've updated the zip file for my hardinge config and can't figure out how the clp file was not included.
I created a weighted sum example for you and it is here . It's probably the terms that scare you but it is a rather simple component. And that being said HAL is very simple like building something with small components one part at a time. Run the example configuration and look at the HAL in the postgui.hal file to see how simple it is to connect once you know how. The man page link is very terse...
JT
John, I was referring to the hardinge.clp file as it is not in your "EMC2 CHNC Config Files" that you down load from your website.
JT
- Thank you received: 5013
04 Jun 2013 22:06 #35257
Just to clarify: Is this a realtime component or a userspace one?
In a userspace component you can look at www.linuxcnc.org/docs/html/man/man3/rtapi_get_time.3rtapi.html
Initialise a variable from this function on entry, then keep checking the difference between the variable and the function return value and exit the loop when it exceeds the limit.
In a realtime component you can't have a wait loop, you will stop the whole machine. Instead you keep a counter and add "fperiod" to it every time through.
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...s/heads/master#l1085
(Line 1085 onwards) is an example of a wait-loop in a realtime module. It uses a state-machine so that it can always run to completion, and some of the states run a timer so that they can exit if they don't see the right result in time. For example case 0x11 starting in line 1234.
Replied by andypugh on topic Timed exit while loop. Best way?
I would like to have a timed exit in a while loop for my hal tool changer component. I am waiting for an input in a loop and if I don't get it in a few seconds I want it to alarm out with a message. I am wondering the best way to achieve this. Probably a stupid question but I am still a newbie to LinuxCNC.
- DaOne
04 Jun 2013 23:07 #35262
by DaOne
ArcEye, I am building my code based on the Orac Toolchanger you wrote. I am just changing some things to make it work with my setup. The biggest issue I had with the Orac Toolchanger code is from my amateur eyes, contains loops that will go on to infinity if it never gets the right signal. The other issue I have with the timer in the Orac file is installing this: sudo comp --install timedelay2.comp The file is nowhere to be found so it says.
Hi
Regards an internal timer can be as simple ascase 1: // programmed delay to allow relays time to change over if(sleeptime < times) { sleeptime++; break; } run = true; progress_level = 2; break;
- DaOne
04 Jun 2013 23:09 #35263
by DaOne
Thanks John, I will give that a look. I appreciate all your help.
JT
- DaOne
04 Jun 2013 23:16 #35264
by DaOne
Andy, its basically the Orac Toolchanger ArcEye wrote just modified to work with my machine. I think this would be considered real time but I am not sure? As far as stopping the whole machine that was kinda the point. What I am trying to do is make it wait for a turret clamped signal. This would be a loop until it gets the signal. The problem with that is what if it never gets the turret clamped signal? I want it to error out and alert the user the turret has an issue and stop the machine not bring the system to a halt (infinity loop). Thank you guys for the help. Not sure I could do this with out it.
Time to create page: 0.218 seconds
