Mesa 7i33 8i20 AC Servo configuration
- buster142
27 Jul 2013 00:27 #37073
by buster142
Mesa 7i33 8i20 AC Servo configuration was created by buster142
Have anyone a sample hal configuration for a mesa 8i20 with encoder/resolver feedback?
Michael
Michael
- Thank you received: 5015
27 Jul 2013 08:24 #37082
I am using 8i20 + 5i23 + 7i49
I can give you my config if you want?
However, it is slightly complicated by also having a pair of 7i39 bldc drives and running those in different ways in different configs.
Replied by andypugh on topic Mesa 7i33 8i20 AC Servo configuration
The following user(s) said Thank You: buster142
- Thank you received: 5300
27 Jul 2013 10:36 - 27 Jul 2013 10:37 #37086
Replied by PCW on topic Mesa 7i33 8i20 AC Servo configuration
freeby.mesanet.com/5i20green.ini
freeby.mesanet.com/hm2-servogreen.hal
Is a hacked version of the hm2-servo demo hal file using the 8I20
and a BLDC motor (a big one painted green for some reason)
Last edit: 27 Jul 2013 10:37 by PCW.
- buster142
28 Jul 2013 23:18 #37171
by buster142
Replied by buster142 on topic Mesa 7i33 8i20 AC Servo configuration
Thanks!
maybe little bit PID tuning but everything is working fine now
29 Jul 2013 03:01 #37181
You might want to fiddle with the bldc.N.encoder-offset if you are using resolvers. My motors seem to need -950000 in that parameter to give the same current/velocity relationship
If you are using the pid-fb-deriv pin, and have it connected to the resolver-velocity pin then be aware that you may need to set the resolver.N.velocity-scale negative to make the Dgain term work properly.
(It was only today that I realised why I had to use a negative Dgain, now I have negated the scale and Dgain is positive again)
This is the machine working (hot off the camera)
Thanks!
- chimeno
- Thank you received: 125
29 Aug 2013 17:49 #38212
by chimeno
Replied by chimeno on topic Mesa 7i33 8i20 AC Servo configuration
hello.
I have a question, I am restoring a cnc machine that lleba 1000w AC servomotors but no driver, my question would be, which is better, buying a new set of servo + driver or ultilizar these old servomotors with the 8I20 + 150v transformer for these servos?
that would make me missing transformer for 3 motors?
thanks
Albert
thanks
Albert
30 Aug 2013 03:10 #38228
The 8i20 is only cheap in the context of servo drives, it still costs quite a lot of money.
Things are a little safer with a transformer.
A good solution in a 240V country and require 150VDC would be to rectify the output of a site isolation transformer.
www.ebay.co.uk/itm/3-3KVA-SITE-TRANSFORM...ND-NEW-/390646842449
Or similar, you would need a good-sized rectifier bridge and some very large low-ESR capacitors too.
Be aware that the combination of large capacitors and high voltage is very dangerous. I made a circuit to discharge the capacitors.
However, if I was doing the same thing again I would use the fact that the 8i20 has voltage feedback to HAL to control the power supply.
I would make it impossible to turn on the machine and power supply if the voltage is >10V. I would also initially power the PSU through a ballast resistor, until the 8i20 said that the voltage was > 100V. Then I would switch out the ballast resistor and enable the machine. I would do all this in HAL.
You need big, high-current capacitors, for example:
www.ebay.co.uk/itm/EVOX-RIFA-PEH200-CAPA...&hash=item5640b68b16
Are you sure that your machine does not still have a Power supply?
I would decide by price. If you can find a matching set of 1kW servo motors and drives then that is probably a good and reliable solution.buying a new set of servo + driver or ultilizar these old servomotors with the 8I20 + 150v transformer for these servos?
You might not even need a transformer. I am running on rectified mains (300VDC) with no transformer.that would make me missing transformer for 3 motors?
- chimeno
31 Aug 2013 00:53 #38261
by chimeno
hello,
No transformer leads because only I have the machine, the control unit is there and what I'm trying to do again, I will continue your advice be if I find a set of servo + driver and if it proves to the 8I20.
thanks
Albert
hello,
thanks
Albert
Time to create page: 0.087 seconds
