Using HAL to switch contactor
- guymalpass
20 Dec 2013 19:44 #41869
by guymalpass
Using HAL to switch contactor was created by guymalpass
Hi, I'm trying to get Linuxcnc to switch a contactor when T2 M6 occurs. I am running a 5i25 7i76 combination and would like an output to go high at T2 M6. Should I be looking to build my own HAL component as I can't figure out a way to achieve this with built in components? If building a component is the way forward it appears that I could use C or Python, yet I am struggling to find out why you may pick one over the other.
Many thanks,
Guy
Many thanks,
Guy
- BigJohnT
- Thank you received: 1175
20 Dec 2013 20:34 #41872
by BigJohnT
Replied by BigJohnT on topic Using HAL to switch contactor
I would use ClassicLadder to switch your output with the tool change code. Are you changing tools or just turning on an output?
gnipsel.com/linuxcnc/index.html
JT
JT
- guymalpass
21 Dec 2013 18:30 #41898
by guymalpass
Replied by guymalpass on topic Using HAL to switch contactor
Thanks JT, I've had a look at your classicladder tutorials and think I'm starting to understand it but I can't figure out how to process tool number information? I've found the relevant hal pin, should I do something with counters do you think?
- guymalpass
21 Dec 2013 18:49 #41899
by guymalpass
I'm using the output to operate a contactor, swapping the VFD from one spindle to anotherAre you changing tools or just turning on an output?
- guymalpass
21 Dec 2013 21:47 #41905
by guymalpass
No problem, just found out about the compare object and I'm away now !
Time to create page: 0.082 seconds
