Delete Components
- simon n.
22 Jan 2014 01:52 #43059
by simon n.
Delete Components was created by simon n.
i just loaded a component via:
sudo comp add_comp.comp
sudo comp --compile add_comp.comp
sudo comp --install add_comp.comp
sudo comp --document add_comp.comp
There is a new .ko file now in the Module folder in "/usr/realtime-2.6.32-122-rtai/modules". If we now try to open our LinuxCNC program it stopped with this error:"insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 File exists"
How can we fix this to get LinuxCNC running again? Or is it possible to delete a installed component?
Greetings
Simon N.
Greetings
Simon N.
- Thank you received: 5291
22 Jan 2014 02:09 #43061
Replied by PCW on topic Delete Components
I think that error normally means you still have an instance of the realtime system running
Sometimes it can be dumped with:
halrun -U
but often you need to reboot
halrun -U
The following user(s) said Thank You: Mario
Time to create page: 0.049 seconds
