How the HAL does this work?
- Engineer Dwayne
12 Mar 2014 02:11 #44690
by Engineer Dwayne
How the HAL does this work? was created by Engineer Dwayne
Okay, I currently am using axis and have a working plasma cutter cnc on parport 0.
Finally, after buying a second parport card with a know chipset I can successfully have stepconf acknowledge that it exists, set the base address and configure it as an output or input card. I can successfully "see" input using hal configuration and "watch" the inputs change when I apply inputs. I haven't really tried the outputs yet, but they do light up leds that have been installed on them so i have no reason to believe they are not working.
Since stepconf doesn't seem to have a screen for the second parallel port assignment, it seems from what I have read I need to use HAL to do that.
Stepconf creates the custom.hal file which is where I believe I should be putting my assignments.
As soon as i put some commands in the HAL file, something like
net parport.1.pin-02-in => parport.1.pin-01-out
linux cnc crashes when I start it. (same sort of error message box as when you have the wrong base address).
I sense that the file is being looked at since it causes a bunch of errors
I would have thought that input pin 2 would turn on the led on pin 1 when an input is applied. But I don't get there cause cnc won't start.
I assume I am missing something.
what's this loadrt and addf stuff?
The goal is to add a torch height controller and a jog button(s). Eventually some ladder logic will be needed, I did find a field to check in stepconf to load that and it seems to appear.
Is there a trick to re-starting cnc without doing a cold boot? If I make changes to stepconf or the custom.hal it appears necessary to do a cold boot every time, or errors occur even on known good configurations.
- Thank you received: 5195
12 Mar 2014 02:28 #44693
Replied by PCW on topic How the HAL does this work?
LinuxCNC is not crashing, it's just politely telling you that you have a syntax error in your HAL file
The format of a net command is:
net SignalName PIN [PIN] [PIN]
and you have
net PIN PIN
you might try
net test_signal parport.1.pin-02-in => parport.1.pin-01-out
and then maybe take a look at this hal tutorial:
linuxcnc.org/docs/html/hal/basic_hal.html
and you have
net PIN PIN
you might try
The following user(s) said Thank You: Engineer Dwayne
- BigJohnT
- Thank you received: 1176
12 Mar 2014 03:41 #44700
by BigJohnT
Replied by BigJohnT on topic How the HAL does this work?
Time to create page: 0.101 seconds
