Charge Pump - Unexpected Output
12 Mar 2014 02:15 #44691 by Engineer Dwayne
Charge Pump - Unexpected Output was created by Engineer Dwayne
When I enable an output pin in stepconf with "charge pump" i would expect to see a signal on that pin that consists of a square wave at some frequency (20hkz?)
I have a pull up resistor 470 ohms on the pin that I have choosen, and nothing happens. My logic probe shows + on the output (no pulsing), so I surmise that the output is not active.
Is there more to it? I plan to build my own retriggerable monostable but I need a signal to monitor first.
12 Mar 2014 07:17 #44715 by cmorley
Replied by cmorley on topic Charge Pump - Unexpected Output
open a terminal and type: man charge_pump
There is the info on the charge pump component.
The frequency is based on the base thread.
Chris M
12 Mar 2014 17:54 #44732 by BigJohnT
Replied by BigJohnT on topic Charge Pump - Unexpected Output
Or if you prefer to browse the components they are at the bottom of this page.
linuxcnc.org/docs/html/
JT
Time to create page: 0.047 seconds
