Suggested Pin for VFD Error Input
- bottleworks
18 Apr 2014 11:27 #46062
by bottleworks
Suggested Pin for VFD Error Input was created by bottleworks
Hello.
Is there a standard/typical/nominal Hal pin for a VFD error input? I don't really want to add it to estop because my motors would loose position. Is there a standard pin for this like "ah, stop everything now, somethings not right, but don't let the motors go limp".
- emcPT
- Thank you received: 139
18 Apr 2014 15:42 #46068
by emcPT
Replied by emcPT on topic Suggested Pin for VFD Error Input
I don't think so, but what you want to achieve depends greatly how your hardware is connected, and what hardware do you have.
You can connect the error so that you request a feedhold, that is probably the most simple approach, or if your hardware allows it, you can place your machine in "stop program" and disable your drives (if your drives have an enable/disable mode, that do not loose position).
I think that there are many other possibility's to your problem.
- bottleworks
18 Apr 2014 21:32 #46084
by bottleworks
Replied by bottleworks on topic Suggested Pin for VFD Error Input
For the hardware, I've got an I/O pin which will go low if there is any fault with the VFD. I don't want the motors to be disabled, because if the fault occurs during a rapid move, the motors will coast to an uncontrolled stop. At that point, they will be out of position.
- Thank you received: 1455
18 Apr 2014 23:23 #46089
Replied by Todd Zuercher on topic Suggested Pin for VFD Error Input
Not specifically. I connected the fault signal from my VFDs to "motion.enable". But it may or may not do exactly what your asking of it. (I don't know if it stops, then places the machine in off, or if it just goes strait to off)
- Thank you received: 2127
19 Apr 2014 12:05 #46102
Replied by cmorley on topic Suggested Pin for VFD Error Input
in pre linuxcnc 2.6:
motion.feed-hold
careful because it can be masked by mcode.
in 2.6+
motion.feed-inhibit
motion.spindle-inhibit
these are non maskable, but feed-inhibit will wait till the end of a spindle synch move, so I think adding the spindle inhibit would cover that.
adding a message would be a nice touch too.
Chris M
motion.feed-hold
in 2.6+
motion.feed-inhibit
Chris M
Time to create page: 0.050 seconds
