Halscope Basics
- greeder88
01 May 2014 16:45 #46507
by greeder88
Halscope Basics was created by greeder88
I'm not getting anywhere. I tried to get Halscope to connect to something and it acts dead.
Obviously I am doing something wrong.
The manual has 11 pages of command prompt entries to get into Halscope.
My AXIS has one button to get into Halscope but this button seems to get me a fake halscope connected to nothing.
My fake halscope has all the right looks but the lines are dead.
So what am I doing wrong?
Thanks in advance.
Thanks in advance.
- BigJohnT
- Thank you received: 1176
01 May 2014 18:26 #46508
by BigJohnT
Replied by BigJohnT on topic Halscope Basics
Did you click on a channel and add a source for the signal?
You also have to pick one channel as the trigger.
Unfortunately I have not completed the Halscope tutorial but my servo tuning tutorial has screen shots that should give enough hints to set up Halscope.
gnipsel.com/linuxcnc/tuning/index.html
JT
JT
- greeder88
01 May 2014 19:12 #46511
by greeder88
Replied by greeder88 on topic Halscope Basics
I tried just about every combination I could. Used the Axis 0 joint velocity command as my source.
I copied your screen shots except using axis 0
I hit force
I jogged my axis, homed my axis,
Tried every combination possible.
Probably tried 10 or maybe 15 attempts.
Still no life on the screen.
Got pretty good with manually changing the numbers in the INI file.
I found the tutorial was nice and brief. Unfortunately for me 10% too brief. For example tune P.
No P was ever shown on the screen shots.
They were all of Axis 1 Ferror
My suggestion is to assume Homer Simpson is who you are teaching.
Homer and I are not that far apart with complex electronics.
You do a fantastic job though. Without your examples I would not be this far along.
I hit force
- BigJohnT
01 May 2014 19:42 - 01 May 2014 19:44 #46512
by BigJohnT
Did you adjust the trigger point using the slider on the right to position the trigger line just above the velocity line?
I'm out of time for this week so someone else will have to step in and help from here.
JT
JT
Last edit: 01 May 2014 19:44 by BigJohnT.
- greeder88
01 May 2014 19:52 #46513
by greeder88
I will try again today paying attention to the slider .
- greeder88
02 May 2014 17:45 #46537
by greeder88
Good news I finally got life to show up on the screen.
Pretty sure it was my Hal File. I had this:
sserial_port_0=300xxx
I changed to this:
sserial_port_0=002xxx
and I got a pulse on the Ferror.
The Halscope is very tricky and touchy so not positive the above was what did the trick but I have life now.
LIfe is good.
I changed to this:
LIfe is good.
- Thank you received: 5200
02 May 2014 20:56 #46538
Replied by PCW on topic Halscope Basics
The sserial mode setting is not related to halscope setup
(It may change the set of available hal pins however)
- greeder88
03 May 2014 00:33 #46541
by greeder88
I am doing good!
Everything is ready to tune.
However...
Halscope is a mystery. I went through the manual as much as my attention span allowed but don't know the basic concept.
I followed John's tutorial but it is too brief for me to figure out.
I can jog away and get nice graphs that I can use my mouse to move around but what is happening? Nothing is sounding different.
How do you change the actual numbers in the .INI file with the Halscope?
Thank You Very Much in advance.
However...
03 May 2014 01:23 #46542
halscope cannot change anything, it is just a tool for
visualization of signals (like an oscilloscope)
For setting INI tuning values, you can use the calibrate menu in axis
The following user(s) said Thank You: greeder88
- greeder88
03 May 2014 02:11 #46545
by greeder88
Now I am on track. Thanks.
I have one issue. My Z axis holds however when I jog the following error goes wild and shuts down.
Other two axis are fine. The Z axis had to have the tach reversed when setting up the amps which is strange since all motors and amps are the same.
I switched motors then amps with the Z axis and no change.
I reversed the encoder wires this way: A+A- changed to A-A+ same with B and Z. This didn't do anything.
The other strange thing about Z is when setting "P" it could take infinity without shaking. X and Y are at 20.
Time to create page: 0.083 seconds
