Homing pins for each axis
04 May 2014 10:15 #46569 by greeder88
Homing pins for each axis was created by greeder88
I have plenty of pins left over so I want to have one homing pin for each axis.
However having trouble getting AXIS happy with my wording.
I can home using pin 07 but as soon as I unblock more than one I get errors.
How should I phrase it to get them working?
# homing pins
#net x-home <= hm2_5i25.0.7i77.0.0.input-05
#net home-switch <= hm2_5i25.0.7i77.0.0.input-06
net home-switch <= hm2_5i25.0.7i77.0.0.input-07
#net home-switch <= hm2_5i25.0.7i77.0.0.input-08
net home-switch => axis.0.home-sw-in
net home-switch => axis.1.home-sw-in
net home-switch => axis.2.home-sw-in
net home-switch => axis.3.home-sw-in
# Use index, to home
net x-index-enable hm2_5i25.0.encoder.00.index-enable <=> axis.0.index-enable
net y-index-enable hm2_5i25.0.encoder.01.index-enable <=> axis.1.index-enable
net Z-index-enable hm2_5i25.0.encoder.02.index-enable <=> axis.2.index-enable
net a-index-enable hm2_5i25.0.encoder.03.index-enable <=> axis.3.index-enable
04 May 2014 13:41 #46571 by ArcEye
Replied by ArcEye on topic Homing pins for each axis
The error message would have been helpful
You can only connect one OUT pin to a signal, so you need a different signal name for each axis for a start.
Have to guess that is the error.
04 May 2014 16:46 #46574 by greeder88
Replied by greeder88 on topic Homing pins for each axis
The error is:
It already has out pin.
The error was longer but nothing help full in the rest.
Am I the only one using separate pins and if not what signal names are people using?
If I am the only person using separate pins is it not recommended?
Thanks in advance.
04 May 2014 17:47 - 04 May 2014 17:57 #46575 by PCW
Replied by PCW on topic Homing pins for each axis
As ArcEye said, you cannot connect multiple 'out' pins to one signal
In your previous hal code you had multiple sources (out pins)
driving a single signal. That is, you had pins hm2_5i25.0.7i77.0.0.input-06,
hm2_5i25.0.7i77.0.0.input-07, and hm2_5i25.0.7i77.0.0.input-08
all driving the signal 'home-switch'
This is a logical conflict. Linuxcnc detects this and aborts the startup.
That is, what value should 'home-switch' take when hm2_5i25.0.7i77.0.0.input-06,
hm2_5i25.0.7i77.0.0.input-07, and hm2_5i25.0.7i77.0.0.input-08 differ?
The solution is to use different signal names. For example:
# homing pins
net x-home-switch <= hm2_5i25.0.7i77.0.0.input-05
net y-home-switch <= hm2_5i25.0.7i77.0.0.input-06
net z-home-switch <= hm2_5i25.0.7i77.0.0.input-07
net a-home-switch <= hm2_5i25.0.7i77.0.0.input-08
net x-home-switch => axis.0.home-sw-in
net y-home-switch => axis.1.home-sw-in
net z-home-switch => axis.2.home-sw-in
net a-home-switch => axis.3.home-sw-in
should work
Note that the signal names are not important except as a guide to function and so:
# homing pins
net red <= hm2_5i25.0.7i77.0.0.input-05
net yellow <= hm2_5i25.0.7i77.0.0.input-06
net blue <= hm2_5i25.0.7i77.0.0.input-07
net green <= hm2_5i25.0.7i77.0.0.input-08
net red => axis.0.home-sw-in
net yellow => axis.1.home-sw-in
net blue => axis.2.home-sw-in
net green => axis.3.home-sw-in
should also work (but is less readable)
Last edit: 04 May 2014 17:57 by PCW. Reason: order
The following user(s) said Thank You: greeder88
04 May 2014 19:13 #46577 by greeder88
Fantastic!
All I can say is this Halloween I am having my wife sew up Superman suits for the grand kids with that goat picture replacing the giant "S".
Time to create page: 0.070 seconds
