How compiling this component ?
23 May 2014 01:31 #47212 by gaston48
How compiling this component ? was created by gaston48
Hello everybody !
what is the problem ?
thank you very much
atanxy.comp
component atanxy;
pin out float out;
pin in float in0;
pin in float in1;
function _;
license "GPL";
#include <rtapi_math.h>
#define PI 3.141592653589
FUNCTION(_) { out = atan2 (in0,in1) * 180 / PI }
23 May 2014 13:53 #47227 by ArcEye
Replied by ArcEye on topic How compiling this component ?
Hi
There is no terminating semicolon after PI
Suspect that is it, parse routine not finding line termination to work on.
23 May 2014 15:04 #47232 by gaston48
Replied by gaston48 on topic How compiling this component ?
Hello ArcEye
thank you for your answer
Yes sorry :blush:
but after correcting the problem is the same.
same post after "$ comp atanxy.comp" ??
23 May 2014 15:13 #47233 by ArcEye
Hi
I think it is just a case of the python parser not being as good at resolving obfusticated C as cpp
This seems to compile fine
component atanxy;
pin out float out;
pin in float in0;
pin in float in1;
function _;
license "GPL";
FUNCTION(_)
    out = (atan2 (in0,in1) * (180 / PI));
23 May 2014 15:42 #47237 by gaston48
Perfect :) thank you.
This is a precaution I take with Pascal but I do not know C + +
and I did not dare ...
23 May 2014 15:58 #47240 by gaston48
Oops, no, the problem is the same :blush: ?
I compile another fichier.comp and it works well ?
23 May 2014 16:02 #47241 by ArcEye
I am not using the same version of comp probably and I did not install the component, just built it.
Try comp --compile atanxy.comp
and be sure that the new one is in the path not the old one
23 May 2014 16:34 #47243 by gaston48
Thank you for your patience
with my comp :
sincos.comp works well
atanxy.comp no ?
File Name: sincos.comp
File Size:0 KB
File Name: atanxy.comp
File Size:0 KB
23 May 2014 16:42 #47244 by ArcEye
Hi
I am working on another partition and cannot test just yet
I did notice however that the atanxy.comp is littered with ^M charactors, which I suspect means it has been edited under windows
That in its own can produce an error
Try cutting and pasting the version I posted into gedit and then compile it
23 May 2014 17:13 #47245 by gaston48
Yes you're right, this is the problem!
But I wrote my atanxy.comp and my sincos.comp in gedit ??
and in gedit, my atanxy.comp and yours are identhique
(I wonder if I is not a keyboard problem)
Time to create page: 0.290 seconds
