How compiling this component ?
- ArcEye
- Thank you received: 758
23 May 2014 17:27 #47246
by ArcEye
Replied by ArcEye on topic How compiling this component ?
Not likely to be anything to do with the keyboard.
Open atanxy.comp in gedit, and then click on SaveAs
At the bottom of the dialog there are options to save with Windows line ending or Linux
If your file already has windows line endings, it looks like it will default to this without you even knowing it.
So you need to check this is correct whenever you save a file and hopefully will not reoccur
- gaston48
- Thank you received: 5
23 May 2014 18:41 - 23 May 2014 19:28 #47248
by gaston48
Replied by gaston48 on topic How compiling this component ?
Yes that's exactly it
Oups,i have not seen this option in gedit.
I had to open before a windows file who set
en of line in hexa:
windows: 0D 0A
linux : 0A 0A
Thank you very much for your help!
en of line in hexa:
windows: 0D 0A
linux : 0A 0A
Last edit: 23 May 2014 19:28 by gaston48.
Time to create page: 0.048 seconds
