How i programm a Spindle Soft Start exactly
- sutter.michi
25 Aug 2014 00:52 #50228
by sutter.michi
How i programm a Spindle Soft Start exactly was created by sutter.michi
Hello, my name is Michi and i would use Linux CNC with my bild CNC machine.
Everything works fine, exclude the Spindle...
I have a circuit which works with frequency uf pulses.
Example:
100Hz -> spindle has 1000 rpm
6000Hz -> spindle has 60000 rpm
I would use pwmgen in PDM mode to generate the pulses.
I need a soft start for the spindle, while my hardware can`t do this...
I have found this exaple for a spindle soft start, but i don`t know waht in my hal code i need to rewrite:
linuxcnc.org/docs/html/examples/spindle.html
Must i write this direct in the hal file or did i need a new one?
And which code exactly i need to replace?
Best regards and thanks a lot for anyones help!!
Michi
Please excuse my bad english, i hope you can understand it
Example:
Michi
- Thank you received: 5215
25 Aug 2014 01:13 - 25 Aug 2014 01:13 #50230
Replied by PCW on topic How i programm a Spindle Soft Start exactly
Since the spindle is controlled by a pulse rate, you should use the stepgen component (in velocity mode)
The stepgen component has the added advantage that it has a programmable acceleration limit for "soft" start and speed change
Last edit: 25 Aug 2014 01:13 by PCW.
- sutter.michi
25 Aug 2014 03:47 #50239
by sutter.michi
Replied by sutter.michi on topic How i programm a Spindle Soft Start exactly
Okay i check this out, and read tomorrow something about the stepgen.
But in which document i need to write the code?
In the HAL - file that is created with the StepConf Wizard, or must i create a new HAL file with only this stepgen code?
Michi
Michi
- BigJohnT
- Thank you received: 1176
26 Aug 2014 20:38 #50313
by BigJohnT
Replied by BigJohnT on topic How i programm a Spindle Soft Start exactly
- sutter.michi
27 Aug 2014 05:23 #50333
by sutter.michi
Hello.
Thanks for your help!
I tryed it again this evening, and with my oszilloskop it seems to functionate
The frequency steps slowly up and down
Can you look at my code, if he is okay this way?
The codelines between the # signs i have addet to the HAL Code which was generated from the StepgenConfig Tool.
Best regards and good night!
Michi
Michi
loadrt trivkins
loadrt [EMCMOT]EMCMOT base_period_nsec=[EMCMOT]BASE_PERIOD servo_period_nsec=[EMCMOT]SERVO_PERIOD num_joints=[TRAJ]AXES
loadrt probe_parport
loadrt hal_parport cfg="0x378 out "
setp parport.0.reset-time 5000
loadrt stepgen step_type=0,0,0
loadrt pwmgen output_type=1
loadrt limit2 names=spindle-ramp
loadrt near names=spindle-at-speed
addf spindle-ramp servo-thread
addf spindle-at-speed servo-thread
setp spindle-ramp.maxv 40
addf pwmgen.make-pulses base-thread
addf stepgen.update-freq servo-thread
#net spindle-cmd <= motion.spindle-speed-out => pwmgen.0.value # <-- this line must be deactivated
net spindle-cmd <= motion.spindle-speed-out => spindle-ramp.in
net spindle-ramped <= spindle-ramp.out => pwmgen.0.value
net spindle-cmd => spindle-at-speed.in1
net spindle-ramped => spindle-at-speed.in2
net spindle-ready <= spindle-at-speed.out => motion.spindle-at-speed
net spindle-on <= motion.spindle-on => pwmgen.0.enable
net spindle-pwm <= pwmgen.0.pwm
setp pwmgen.0.pwm-freq 0.0
setp pwmgen.0.scale 60595.959596
setp pwmgen.0.offset 0.00983497249542
setp pwmgen.0.dither-pwm true
net spindle-cw <= motion.spindle-forward
net estop-out => parport.0.pin-01-out
net xstep => parport.0.pin-02-out
setp parport.0.pin-02-out-reset 1
net xdir => parport.0.pin-03-out
net ystep => parport.0.pin-04-out
setp parport.0.pin-04-out-reset 1
net ydir => parport.0.pin-05-out
net zstep => parport.0.pin-06-out
setp parport.0.pin-06-out-reset 1
net zdir => parport.0.pin-07-out
net spindle-on => parport.0.pin-08-out
net spindle-pwm => parport.0.pin-09-out
net spindle-cw => parport.0.pin-14-out
net spindle-pwm => parport.0.pin-16-out
net xenable => parport.0.pin-17-out
setp stepgen.0.position-scale [AXIS_0]SCALE
setp stepgen.0.steplen 1
setp stepgen.0.stepspace 0
setp stepgen.0.dirhold 35000
setp stepgen.0.dirsetup 35000
setp stepgen.0.maxaccel [AXIS_0]STEPGEN_MAXACCEL
net xpos-cmd axis.0.motor-pos-cmd => stepgen.0.position-cmd
net xpos-fb stepgen.0.position-fb => axis.0.motor-pos-fb
net xstep <= stepgen.0.step
net xdir <= stepgen.0.dir
net xenable axis.0.amp-enable-out => stepgen.0.enable
setp stepgen.1.position-scale [AXIS_1]SCALE
setp stepgen.1.steplen 1
setp stepgen.1.stepspace 0
setp stepgen.1.dirhold 35000
setp stepgen.1.dirsetup 35000
setp stepgen.1.maxaccel [AXIS_1]STEPGEN_MAXACCEL
net ypos-cmd axis.1.motor-pos-cmd => stepgen.1.position-cmd
net ypos-fb stepgen.1.position-fb => axis.1.motor-pos-fb
net ystep <= stepgen.1.step
net ydir <= stepgen.1.dir
net yenable axis.1.amp-enable-out => stepgen.1.enable
setp stepgen.2.position-scale [AXIS_2]SCALE
setp stepgen.2.steplen 1
setp stepgen.2.stepspace 0
setp stepgen.2.dirhold 35000
setp stepgen.2.dirsetup 35000
setp stepgen.2.maxaccel [AXIS_2]STEPGEN_MAXACCEL
net zpos-cmd axis.2.motor-pos-cmd => stepgen.2.position-cmd
net zpos-fb stepgen.2.position-fb => axis.2.motor-pos-fb
net zstep <= stepgen.2.step
net zdir <= stepgen.2.dir
net zenable axis.2.amp-enable-out => stepgen.2.enable
net estop-out => iocontrol.0.emc-enable-in
net tool-change iocontrol.0.tool-change => hal_manualtoolchange.change
net tool-changed iocontrol.0.tool-changed <= hal_manualtoolchange.changed
Time to create page: 0.055 seconds
