LInuxCNC 2.6.3 encoder.N.min-velocity-estimate
10 Oct 2014 00:41 #51924 by ye11
Hi
Docs for LInuxCNC 2.6 contain such parameter for encoder as min-velocity-estimate. But in fact there is no that parameter. There is old min-speed-estimate.
And it does not work. I dont see encoder.N.velocity became zero, when it less min-speed-estimate.
10 Oct 2014 18:23 #51940 by andypugh
Replied by andypugh on topic LInuxCNC 2.6.3 encoder.N.min-velocity-estimate
Hi
You seem to be right: git.linuxcnc.org/gitweb?p=linuxcnc.git;a...=refs/heads/2.6#l590
The value is used around line 473. I am not clear if it is rpm or rps based. It also appears that if you have encoder count dither it won't activate. I can see that dither in an axis might keep the encoder dithering so that the two elements keep each other "awake". I am not sure what you are trying to do with the pin, but it may be that PID deadband would be a better thing to try.
10 Oct 2014 18:58 - 10 Oct 2014 19:00 #51942 by ye11
Documention says 'The units of min-velocity-estimate are the same as the units of velocity', so it rps based in my case.
I'm using encoder component simply for sensing spindle speed and nothing more.
When spindle have stoped, velocity isn't zero. So I thought, this parameter was made exactly for this.
Last edit: 10 Oct 2014 19:00 by ye11.
12 Oct 2014 16:19 - 12 Oct 2014 16:22 #51975 by ye11
After debugging i've selected the value of min-speed-estimate.
I have 100 holes encoder and set position-scale 200. So when my spindle rotates 100 rpm, i have velocity about 1.7 (it's rps, as you see).
Before i've tried to set min-speed-velocity in values like 0.01. And it didn't work.
Now when i set min-speed-estimate 500, all works corectly.
So the units of min-speed-estimate aren't the same as the units of velocity!
Last edit: 12 Oct 2014 16:22 by ye11.
12 Oct 2014 16:59 #51977 by cncbasher
Replied by cncbasher on topic LInuxCNC 2.6.3 encoder.N.min-velocity-estimate
what exactly is your problem , as you dont mention it , rather than what your are trying
Time to create page: 0.066 seconds
