Custom kins component
- dimech
22 Oct 2014 20:23 #52274
by dimech
Replied by dimech on topic Custom kins component
Unfortunately I could not overcome the problem. Same warnings!
Should I have to mention that I am running linuxCNC through Lubuntu 12.04.4 precise
Also I copy the pumakins.ko file from linuxcnc-dev directory to /usr/realtime-3.4-9-rtai-686-pae/modules/linuxcnc and now puma kins works properly
Thank you!
Thank you!
- Thank you received: 4968
22 Oct 2014 20:46 #52275
This sounds like you are not issuing the . ./scripts/rip-environment command (yes, it really is dot space dot slash). This is a per-terminal-window thing, and you will only be able to run your newly-compiled run-in-place LinuxCNC from the command line unless you make a link to the linuxCNC start script in the linuxcnc-dev/scripts folder. (we will come back to this).
The way to compile your kins is _probably_ . ./scripts/rip-enviroment and then sudo halcompile --install {your kins file.c}
Alternatively, you can add your kins file to the makefile, copying the format of the other kinematics files: git.linuxcnc.org/gitweb?p=linuxcnc.git;a...73006f4;hb=HEAD#l941
But halcompile (or comp, depending on your LinuxCNC version) is likely to be easier. (though you will see that the makefile adds references to posemath, which might be important).
If you want to compile your modified LinuxCNC as an installed version, rather than as a run-in-place version (which is admittedly more convenient) then you need to specify a prefix at the ./configure stage.
There is some info here: git.linuxcnc.org/gitweb?p=linuxcnc.git;a...c52995f6f38c;hb=HEAD
Though oddly that doesn't mention compiling a non-rip version. I happen to know that you need to use
./configure --prefix=/usr
But I can't actually find any mention of that in the docs...
Replied by andypugh on topic Custom kins component
That's fine, so am I.Should I have to mention that I am running linuxCNC through Lubuntu 12.04.4 precise
The following user(s) said Thank You: dimech
- dimech
22 Oct 2014 21:37 #52276
by dimech
Andy you are AMAZING!
I cannot thank you enough!
I did it with the Makefile way and it works.
Time to create page: 0.073 seconds
