Charge Amp Frequency
02 Nov 2014 01:47 #52672 by Todd Zuercher
Replied by Todd Zuercher on topic Charge Amp Frequency
The problem is you can normally only change the state of a parallel port pin once per thread cycle. You are turning it on one cycle then the next thread cycle you are turning it off. The exception to that is when you use reset. In that case the pin is changed at the start of the cycle, then changed back after the specified reset time. The downside of using the reset is nothing else gets done while counting down the reset time (I might be wrong about this).
The following user(s) said Thank You: SteveT
02 Nov 2014 02:32 #52673 by PCW
Replied by PCW on topic Charge Amp Frequency
This is getting way too complicated
Why not just set your base thread to 24 KHz, (41666 ns) and see if the chargepump actually works
If it is in fact a real chargepump (not a ucontroller based watchdog that senses frequency)
it will be largely insensitive to the exact frequency used.
If it does indeed sense frequency, then you should be able to use the fastest basethread
you can and generate a 12 KHz ~square wave with a stepgen running in velocity mode
02 Nov 2014 18:45 - 03 Nov 2014 01:09 #52686 by SteveT
Replied by SteveT on topic Charge Pump Frequency
Hi tried setting the base thread to 41666 with no luck, will try the SIGGEN at some time but for now have disabled to charge-pump circuit.
Thanks for everyone's help
Steve
Last edit: 03 Nov 2014 01:09 by SteveT.
03 Nov 2014 04:16 #52699 by andypugh
Replied by andypugh on topic Charge Pump Frequency
The chances are that it isn't the frequency that is the problem. It might possibly be the current required. The charge-pump on the Gecko G540, for example, needs rather more current than the standard parallel port can provide.
Putting the port into EPP mode sometimes (indirectly) makes it work.
