streamer/halstreamer doesn't work?!? BUG!
- eslavko
- Thank you received: 4
15 Nov 2014 02:27 - 15 Nov 2014 16:39 #53093
by eslavko
streamer/halstreamer doesn't work?!? BUG! was created by eslavko
Hello I have trouble setting up streamer component.
In hal I added these lines:
and started halmeter to monitor streamer.0.curr-depth
at start I suspects to be 0 and it is. but then I open console and just invoke halstreamer.
Now if I enter number 0 or 1 (and press enter) I expect that cur-depth should increase by 1 as streamer is disabled by setp. If I enter "wrong" character 5 as example in halstreamer it report that line is skipped. So where data goes?
loadrt streamer depth=10000 cfg=b
setp streamer.0.enable 0
addf streamer.0 base-thread
Last edit: 15 Nov 2014 16:39 by eslavko. Reason: Changed subject
- eslavko
15 Nov 2014 16:50 #53109
by eslavko
Replied by eslavko on topic streamer/halstreamer doesn't work?!? BUG!
Hello...
After more digging in streamer I can declared that it's have BUG.
I do the check the source streamer.c (with my limited C knowledge).
if streamer.x.enable = false then none of other parameters are updated as update routine exit immediatly.
I think that
should be repositioned at least after line
And making another pin named clock/clocktype should be nice to. I think something like:
streamer.x.clocktype 0(default) no clock - stream by call rate. 1=falling edge, 2=rising edge, 3=both edges
streamer.c.clock
I can probably do that but code will be messy as I'm not C programmer.
I think that
/* are we enabled? */
if ( ! *(str->enable) ) {
/* no, done */
return;
*(str->curr_depth) = tmpin - tmpout;
streamer.c.clock
- eslavko
15 Nov 2014 18:02 #53111
by eslavko
Hello...
Can someone help me to proffread the code needed for adding clock.
I know that I need to add new parameters and new pins.
Actualy I need to add storage for old clock value, new clock pin and parameter clock type.
and working code something like this
I don't know how to proper manage pointers. checking the code sometime is (*something) other time is *(something) and I don't know the difference.
Thanks in advice.
Slavko.
/* Clock option added by eSlavko */
/* clocktype 0 means no clocking - step every call */
/* clocktype 1 means faling edge */
/* clocktype 2 means rising edge */
/* clocktype 3 means both edges */
/* make update old clock value (just swap old and new clock) */
n=(str->oldclock);
(str->oldclock)=(str->clock);
(str->clock)=n;
/* no, done */
return;
switch (str->clocktype ) {
case 0:
break;
case 1:
if (str->clock & !str->oldclock){
return; //invalid edge - finish
break;
case 2:
if (!str->clock & str->oldclock){
break;
case 3:
if (str->clock ^ str->oldclock){
return; //none edge - finish
break;
/* end of clock option*/
Thanks in advice.
Slavko.
- ArcEye
- Thank you received: 758
15 Nov 2014 19:51 #53115
by ArcEye
Replied by ArcEye on topic streamer/halstreamer doesn't work?!? BUG!
Hi
I have never used streamer, but would have thought that the enable pin preventing updates if 0 was deliberate, so that it could be switched on and off whilst still loaded.
Regards pointers in C
streamer_t *str; allocates a pointer to a memory location at which a value of type streamer_t can be found
*str references the value pointed to by the pointer rather than the address it is at.
So for example
// allocate a variable of type double and give it value 200
double d = 200;
// create a pointer to a double value
double *double_ptr;
// pass the address of d to the pointer
double_ptr = &d;
// pointer now points to d and value can be referenced by *(ptr) dereferencing
*(double_ptr) is now 200
hope that assists
So for example
double d = 200;
double *double_ptr;
double_ptr = &d;
hope that assists
- eslavko
15 Nov 2014 20:32 #53119
by eslavko
I think that enable should just enable IO operation, but status should be updated regardles of enable.
So if FIFO is empty and then enable is set to false we should read empty bit as true. But when new data arrive the fifo is not empty and bit empty should toogle to false. I hav managed to correct that. Now I just stumbling to add clock pin.
I think this update is essential if streamer is used for raster imaging. As FIFO fill is userspace component in this way we can monitor from gcode if fifo is ready for next line
Hi
- eslavko
15 Nov 2014 22:35 #53124
by eslavko
Hello....
Finally I got fix.
But realy don't know how to update it. I think that streamer has now much better capability as before.
Changes are:
The status (curr-depth, empty, underruns) are reported correctly even if enable is false.
And addition for clock (by default param is same as without change).
There are streamer.N.clock pin for data clocking
and streamer.N.clock-mode.
Mode 0 (default) just ingore clock pin and do as before.
Mode 1 means falling edge of clock
Mode 2 means rising edge of clock
Mode 3 means both edges of clock
With this we can now connect step pulse to clock and get rastering with sinc of stepper motion.
Can someone update streamer.c file? I was trying with git but I do some mess... so please.
in the begining of file is comment to put in manual too.
Finally I got fix.
Changes are:
* Description: streamer.c
* A HAL component that can be used to stream data
* from a file onto HAL pins at a specific realtime
* sample rate.
* Author: John Kasunich <jmkasunich at sourceforge dot net>
* License: GPL Version 2
* Copyright (c) 2006 All rights reserved.
/** This file, 'streamer.c', is the realtime part of a HAL component
that allows numbers stored in a file to be "streamed" onto HAL
pins at a uniform realtime sample rate. When the realtime module
is loaded, it creates a fifo in shared memory. Then, the user
space program 'hal_streamer' is invoked. 'hal_streamer' takes
input from stdin and writes it to the fifo, and this component
transfers the data from the fifo to HAL pins.
Loading:
loadrt streamer depth=100 cfg=uffb
/** Copyright (C) 2006 John Kasunich
/** This program is free software; you can redistribute it and/or
modify it under the terms of version 2 of the GNU General
Public License as published by the Free Software Foundation.
This library is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public
License along with this library; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111 USA
THE AUTHORS OF THIS LIBRARY ACCEPT ABSOLUTELY NO LIABILITY FOR
ANY HARM OR LOSS RESULTING FROM ITS USE. IT IS _EXTREMELY_ UNWISE
TO RELY ON SOFTWARE ALONE FOR SAFETY. Any machinery capable of
harming persons must have provisions for completely removing power
from all motors, etc, before persons enter any danger area. All
machinery must be designed to comply with local and national safety
codes, and the authors of this software can not, and do not, take
any responsibility for such compliance.
This code was written as part of the EMC HAL project. For more
information, go to www.linuxcnc.org.
/* 15. November 2014 addition by eslavko
* streamer.N.cur-depth, streamer.N.empty and streamer.N.underruns are
* now (correctly) updated even if streamer.N.enabled is set to false.
* in addition there are two new pins to enable clocking streamer.
* by default values the streamer behaviour is as before update.
* the new pin is
* streamer.N.clock bit input
* it's clock input with actions defined by clock_mode pin.
* streamer.N.clock-mode s32 input
* define behaviour of clock pin.
* value 0 (default) freerun at every loop
* value 1 means clock by falling edge
* value 2 means clock by rising edge
* value 3 meand clock by any edge
#include "rtapi.h" /* RTAPI realtime OS API */
#include "rtapi_app.h" /* RTAPI realtime module decls */
#include "hal.h" /* HAL public API decls */
#include "streamer.h" /* decls and such for fifos */
#include "rtapi_errno.h"
#include "rtapi_string.h"
/* module information */
MODULE_AUTHOR("John Kasunich");
MODULE_DESCRIPTION("Realtime File Streamer HAL");
MODULE_LICENSE("GPL");
static char *cfg[MAX_STREAMERS]; /* config string, no default */
RTAPI_MP_ARRAY_STRING(cfg,MAX_STREAMERS,"config string");
static int depth[MAX_STREAMERS]; /* depth of fifo, default 0 */
RTAPI_MP_ARRAY_INT(depth,MAX_STREAMERS,"fifo depth");
* STRUCTURES AND GLOBAL VARIABLES *
/* this structure contains the HAL shared memory data for one streamer */
typedef struct {
fifo_t *fifo; /* pointer to user/RT fifo */
hal_s32_t *curr_depth; /* pin: current fifo depth */
hal_bit_t *empty; /* pin: underrun flag */
hal_bit_t *enable; /* pin: enable streaming */
hal_s32_t *underruns; /* pin: number of underruns */
hal_bit_t *clock; /* pin: clock input */
hal_s32_t *clock_mode; /* pin: clock mode */
} streamer_t;
/* other globals */
static int comp_id; /* component ID */
static int myclockedge; /* clock edge detector */
static int shmem_id[MAX_STREAMERS];
* LOCAL FUNCTION DECLARATIONS *
static int parse_types(fifo_t *f, char *cfg);
static int init_streamer(int num, fifo_t *tmp_fifo);
static void update(void *arg, long period);
* INIT AND EXIT CODE *
int rtapi_app_main(void)
int n, numchan, max_depth, retval;
fifo_t tmp_fifo[MAX_STREAMERS];
/* validate config info */
for ( n = 0 ; n < MAX_STREAMERS ; n++ ) {
if (( cfg[n] == NULL ) || ( *cfg == '\0' ) || ( depth[n] <= 0 )) {
break;
tmp_fifo[n].num_pins = parse_types(&(tmp_fifo[n]), cfg[n]);
if ( tmp_fifo[n].num_pins == 0 ) {
rtapi_print_msg(RTAPI_MSG_ERR,
"STREAMER: ERROR: bad config string '%s'\n", cfg[n]);
return -EINVAL;
max_depth = MAX_SHMEM / (sizeof(shmem_data_t) * tmp_fifo[n].num_pins);
if ( depth[n] > max_depth ) {
"STREAMER: ERROR: depth too large, max is %d\n", max_depth);
return -ENOMEM;
tmp_fifo[n].depth = depth[n];
if ( n == 0 ) {
"STREAMER: ERROR: no channels specified\n");
return -EINVAL;
numchan = n;
/* clear shmem IDs */
shmem_id[n] = -1;
/* have good config info, connect to the HAL */
comp_id = hal_init("streamer");
if (comp_id < 0) {
rtapi_print_msg(RTAPI_MSG_ERR, "STREAMER: ERROR: hal_init() failed\n");
return -EINVAL;
/* create the streamers - allocate memory, export pins, etc. */
for (n = 0; n < numchan; n++) {
retval = init_streamer(n, &(tmp_fifo[n]));
if (retval != 0) {
"STREAMER: ERROR: streamer %d init failed\n", n);
hal_exit(comp_id);
return retval;
rtapi_print_msg(RTAPI_MSG_INFO,
"STREAMER: installed %d data streamers\n", numchan);
hal_ready(comp_id);
return 0;
void rtapi_app_exit(void)
int n;
/* free any shmem blocks */
if ( shmem_id[n] > 0 ) {
rtapi_shmem_delete(shmem_id[n], comp_id);
hal_exit(comp_id);
* REALTIME COUNTER COUNTING AND UPDATE FUNCTIONS *
streamer_t *str;
fifo_t *fifo;
pin_data_t *pptr;
shmem_data_t *dptr;
int tmpin, tmpout, n, doclk;
/* point at streamer struct in HAL shmem */
str = arg;
/* keep last two clock states to get all possible clock edges */
myclockedge=((myclockedge<<1) | (*(str->clock) & 1)) & 3;
/* are we enabled? - generate doclock if enabled and right mode */
doclk=0;
if ( *(str->enable) ) {
doclk=1;
switch (*str->clock_mode) {
/* clock-mode 0 means do clock if enabled */
case 0:
break;
/* clock-mode 1 means enabled & faling edge */
case 1:
if ( myclockedge!=2) {
doclk=0;
break;
/* clock-mode 2 means enabled & rising edge */
case 2:
if ( myclockedge!=1) {
doclk=0;
break;
/* clock-mode 3 means enabled & both edges */
case 3:
if ((myclockedge==0) | ( myclockedge==3)) {
doclk=0;
break;
default:
break;
/* HAL pins are right after the streamer_t struct in HAL shmem */
pptr = (pin_data_t *)(str+1);
/* point at user/RT fifo in other shmem */
fifo = str->fifo;
/* fifo data area is right after the fifo_t struct in shmem */
dptr = (shmem_data_t *)(fifo+1);
/* find the next block of data in the fifo */
tmpin = fifo->in;
tmpout = fifo->out;
if (tmpout == tmpin) {
/* fifo empty - log it */
*(str->empty) = 1;
*(str->curr_depth) = 0;
/* increase underrun only for valid clock*/
if (doclk==1){
(*str->underruns)++;
/* done - output pins retain current values */
return;
/* clear the "empty" pin */
*(str->empty) = 0;
/* calculate current depth */
if ( tmpin < tmpout ) {
tmpin += fifo->depth;
/* don't preceed if there are no valid clock*/
if (doclk==0){
return;
/* make ptr to first data item of the current fifo record */
dptr += tmpout * fifo->num_pins;
/* copy data from fifo to HAL pins */
for ( n = 0 ; n < fifo->num_pins ; n++ ) {
switch ( fifo->type[n] ) {
case HAL_FLOAT:
*(pptr->hfloat) = dptr->f;
break;
case HAL_BIT:
if ( dptr->b ) {
*(pptr->hbit) = 1;
} else {
*(pptr->hbit) = 0;
break;
case HAL_U32:
*(pptr->hu32) = dptr->u;
break;
case HAL_S32:
*(pptr->hs32) = dptr->s;
break;
default:
break;
dptr++;
pptr++;
tmpout++;
if ( tmpout >= fifo->depth ) {
tmpout = 0;
/* store new value of out */
fifo->out = tmpout;
* LOCAL FUNCTION DEFINITIONS *
char *c;
int n;
c = cfg;
n = 0;
while (( n < MAX_PINS ) && ( *c != '\0' )) {
switch (*c) {
case 'f':
case 'F':
f->type[n++] = HAL_FLOAT;
c++;
break;
case 'b':
case 'B':
f->type[n++] = HAL_BIT;
c++;
break;
case 'u':
case 'U':
f->type[n++] = HAL_U32;
c++;
break;
case 's':
case 'S':
f->type[n++] = HAL_S32;
c++;
break;
default:
"STREAMER: ERROR: unknown type '%c', must be F, B, U, or S\n", *c);
return 0;
if ( *c != '\0' ) {
/* didn't reach end of cfg string */
"STREAMER: ERROR: more than %d items\n", MAX_PINS);
return 0;
return n;
int size, retval, n, usefp;
void *shmem_ptr;
streamer_t *str;
pin_data_t *pptr;
fifo_t *fifo;
char buf[HAL_NAME_LEN + 1];
/* alloc shmem for base streamer data and user specified pins */
size = sizeof(streamer_t) + tmp_fifo->num_pins*sizeof(pin_data_t);
str = hal_malloc(size);
if (str == 0) {
"STREAMER: ERROR: couldn't allocate HAL shared memory\n");
return -ENOMEM;
/* export "standard" pins and params */
retval = hal_pin_bit_newf(HAL_OUT, &(str->empty), comp_id,
"streamer.%d.empty", num);
if (retval != 0 ) {
"STREAMER: ERROR: 'empty' pin export failed\n");
return -EIO;
retval = hal_pin_bit_newf(HAL_IN, &(str->enable), comp_id,
"streamer.%d.enable", num);
if (retval != 0 ) {
"STREAMER: ERROR: 'enable' pin export failed\n");
return -EIO;
retval = hal_pin_s32_newf(HAL_OUT, &(str->curr_depth), comp_id,
"streamer.%d.curr-depth", num);
if (retval != 0 ) {
"STREAMER: ERROR: 'curr_depth' pin export failed\n");
return -EIO;
retval = hal_pin_s32_newf(HAL_IO, &(str->underruns), comp_id,
"streamer.%d.underruns", num);
if (retval != 0 ) {
"STREAMER: ERROR: 'underruns' pin export failed\n");
return -EIO;
retval = hal_pin_bit_newf(HAL_IN, &(str->clock), comp_id,
"streamer.%d.clock", num);
if (retval != 0 ) {
"STREAMER: ERROR: 'clock' pin export failed\n");
return -EIO;
retval = hal_pin_s32_newf(HAL_IN, &(str->clock_mode), comp_id,
"streamer.%d.clock-mode", num);
if (retval != 0 ) {
"STREAMER: ERROR: 'clock_mode' pin export failed\n");
return -EIO;
/* init the standard pins and params */
*(str->empty) = 1;
*(str->enable) = 1;
*(str->underruns) = 0;
*(str->clock_mode) = 0;
usefp = 0;
/* export user specified pins (the ones that stream data) */
for ( n = 0 ; n < tmp_fifo->num_pins ; n++ ) {
rtapi_snprintf(buf, sizeof(buf), "streamer.%d.pin.%d", num, n);
retval = hal_pin_new(buf, tmp_fifo->type[n], HAL_OUT, (void **)pptr, comp_id );
if (retval != 0 ) {
"STREAMER: ERROR: pin '%s' export failed\n", buf);
return -EIO;
/* init the pin value */
switch ( tmp_fifo->type[n] ) {
case HAL_FLOAT:
*(pptr->hfloat) = 0.0;
usefp = 1;
break;
case HAL_BIT:
*(pptr->hbit) = 0;
break;
case HAL_U32:
*(pptr->hu32) = 0;
break;
case HAL_S32:
*(pptr->hs32) = 0;
break;
default:
break;
pptr++;
/* export update function */
rtapi_snprintf(buf, sizeof(buf), "streamer.%d", num);
retval = hal_export_funct(buf, update, str, usefp, 0, comp_id);
if (retval != 0) {
"STREAMER: ERROR: function export failed\n");
return retval;
/* alloc shmem for user/RT comms (fifo) */
size = sizeof(fifo_t) + tmp_fifo->num_pins * tmp_fifo->depth * sizeof(shmem_data_t);
shmem_id[num] = rtapi_shmem_new(STREAMER_SHMEM_KEY+num, comp_id, size);
if ( shmem_id[num] < 0 ) {
"STREAMER: ERROR: couldn't allocate user/RT shared memory\n");
return -ENOMEM;
retval = rtapi_shmem_getptr(shmem_id[num], &shmem_ptr);
if ( retval < 0 ) {
"STREAMER: ERROR: couldn't map user/RT shared memory\n");
return -ENOMEM;
fifo = shmem_ptr;
str->fifo = fifo;
/* copy data from temp_fifo */
*fifo = *tmp_fifo;
/* init fields */
fifo->in = 0;
fifo->out = 0;
fifo->last_sample = 0;
/* mark it inited for user program */
fifo->magic = FIFO_MAGIC_NUM;
return 0;
The following user(s) said Thank You: cncbasher
- ArcEye
15 Nov 2014 22:52 #53125
by ArcEye
If you want to have the file changed to the way you did it, you need to convince the developers it was broken and that this fixes it.
details of submission process here
www.linuxcnc.org/docs/html/code/Contributing-to-LinuxCNC.html
- eslavko
15 Nov 2014 23:43 #53126
by eslavko
Hello...
I was thinking that developers check that forum too.
I was send mail to emc-developers now.
- Thank you received: 5018
20 Nov 2014 01:01 #53216
I find this aspect of C syntax to be less clear than it could be.
For a variable X:
X returns the value of X.
*X returns the value stored at memory address X
&X returns the memory address where the value of X is stored.
Where the confusion arises is when you declare the variable.
int *P
creates a variable that is a pointer to an integer. The value of P is a memory location, and *P will return the value that you store there.
However, the syntax doesn't look like that, really. I tend to read it to myself as int* P, ie P is of type pointer-to-integer.
There are a lot of pointers in LinuxCNC. In fact all a HAL pin is is a pointer to shared memory. When you "net" a HAL pin all that really happens is that all the pins in the net get their pointer address set to the same bit of memory, so all the internal variables in the code read the same value out of the memory.
Replied by andypugh on topic streamer/halstreamer doesn't work?!? BUG!
For a variable X:
int *P
- eslavko
20 Nov 2014 02:43 #53218
by eslavko
Andy the pointer stuf is solved. Actualy the whole thing is solved at least for me. The streamer.c works with new pins. I just share that as I think someone other may find it usable.
..and when version is updated I don't need to make change again...
Slavko.
p.s.
in developer mailing list I post same code but nobody "care" as no answers/comment yet.
Slavko.
p.s.
Time to create page: 0.093 seconds
