Couple of XHC-HB04 use questions
23 Dec 2014 00:30 #54225 by photomankc
Couple of XHC-HB04 use questions was created by photomankc
So I have purchased and setup the XHC-HB04 wired pendant(18 button) and ripped out the old joypad. This thing is awesome by comparison and makes my work a LOT easier setting up. I have a few questions that I didn't see addressed elsewhere.
1.) Does every button have possible "Synthesized" X,Y,Z,A variations? The "=_" keys all have these and that allows me to use "=1/2" for quick offset zeros when using the edge finder and the "=0" button to set absolute zero but there are a few other functions that would be really nice if I could do that with Macro3 or the other Macro keys. Is it just a matter of adding "-x, -y, -z, -a" to the key name for those or is that hardcoded only to the "=_" keys?
2.) Is there a way to have one of the keys press enter for me? When changing TTS tools manually the GUI pops up a dialog and that means I have to walk over to the keyboard, press enter, and walk back to monitor the machine. It would be nice if I could assign a macro key to press enter for me instead so I can do a tool change with just the pendant.
3.) Is it possible to use the keys in an OR situation with hal inputs and postgui.hal? So I want to be able to switch to manual mode with the pendant if the machine gets into MDI sometimes from an operation. I have buttons on my control panel that originally were 'wired' in an OR with the Joypad so that either device could press a button and select manual mode or MDI mode. With the pendant, I had to give it direct control of the hal pins for that and disconnect that from the control panel. I tried using the HAL syntax for one of the OR pins in the macro line for a button in the machine .ini file and while it did not generate an error, it also did not work. I suppose if there is an answer to number 2 then that could also be used for this as well.
23 Dec 2014 04:18 #54236 by dgarrett
Replied by dgarrett on topic Couple of XHC-HB04 use questions
No, per the README:
If the configuration file includes buttons named:
button-zero
button-goto-zero
button-half
then the driver creates additional buttons for these that are active only if
the axis is selected by the rotary switch.
git.linuxcnc.org/gitweb?p=linuxcnc.git;a...ME;hb=refs/heads/2.7
You can see all the pins created from the cmdline (without running LinuxCNC:
$ xhc-hb04 --help  # to see options
$ xhc-hb04         # show pins (without LinuxCNC running)
If LinuxCNC is running, you can see all pins with:
$ halcmd show pin xhc-hb04.
Assuming you are using axis_manualtoolchange.hal or similar, it loads a
user_comp named hal_manualtoolchange. This component has an unconnected pin that can be connected to a button hal_manualtoolchange.change_button):
halcmd show pin hal_manualtoolchange
postgui.hal?
You can do almost anything with Hal but no standard configuration will meet
everyone's wishes.
The xhc-hb04 demo configs use [HAL]HALFILE=xhc-hb04.tcl that 1)reads the ini file for common configuration settings, 2) loadusr the xhc-hb04 user_comp, and 3)hooks up the pendant using the xhc_hb04_util helper component. The helper component is described:
$ man xhc_hb04_util
You can make your own configuration using _just_ the xhc-hb04 userland component and (optionally) the xhc_hb04_util component and add any logic you want _without_ using the xhc-hb04.tcl halfile.
It is instructive to to load your config that uses [HAL]HALFILE=xhc-hb04.tcl
(or a similar sim demo) with the ini file options that you want and then save
the hal configuration with:
$ halcmd show     >hal.show
$ halcmd save all >saveall.hal
The hal.show file shows the entire hal configuration; the saveall.hal file lists all the hal commands (except user land commands like loadusr).
Using these files as a guide, you can make your own hal configuration and add whatever logic you need. Two methods are:
1) Use your existing [HAL]HALFILE= configuration but add new HALFILEs to a) delete some signals and/or unlink some pins (using the hal commands delsig and unlinkp), b) add components and new wiring connections for additional, custom
logic.
2) Make a new set of HALFILEs with the components and logic for your
configuration using the saveall.hal listing as a guide (especially for ordering
addf lines).
The following user(s) said Thank You: photomankc, nkp
23 Dec 2014 15:14 #54254 by photomankc
Replied by photomankc on topic Couple of XHC-HB04 use questions
Thanks for that. I should have copied the README out of the SIM folder. My Bad on that. I guess I would say number 1 would be a feature request im my mind. Lots of functionality could be added if any button could do different actions on X/Y/Z/A.
hal_manualtoolchange - Perfect.... That will solve my biggest gripe right now. I can live with MDI/Manual being tied to the pendant only. The toolchange input will make a lot of difference for me.
Time to create page: 0.161 seconds
