getting started with 8i20
16 Jan 2015 04:17 #55042 by clematites93
Replied by clematites93 on topic getting started with 8i20
In the man bldc, I read this information :
bldc.N.init
........ "The alignement process will tend to cause a following error if it is triggered while the axis is enabled, so should be set before the matching axis.N.enable pin. The complementary init-done pin can be used to handle the requiered seqencing."
Please, help me.
16 Jan 2015 04:27 #55043 by andypugh
Replied by andypugh on topic getting started with 8i20
What is the question?
16 Jan 2015 05:26 #55047 by clematites93
My HAL file is derived from Ted Hyde's original hm2-servo config
# axis enable chain
newsig emcmot.00.enable bit
sets emcmot.00.enable FALSE
net emcmot.00.enable => pid.x.enable
net emcmot.00.enable => bldc.0.init
net emcmot.00.enable => hm2_7i43.0.8i20.amp_enable
net emcmot.00.enable <= axis.0.amp-enable-out
With Axis, my motor turn a little then an error join appears immediately
The alignement process is failed.
How to use the pin init done to avoid this ?
16 Jan 2015 05:47 #55049 by andypugh
Try connecting the init pin to iocontrol.0.user-enable-out so that the drives home as soon as you go out of e-stop.
Then connect init-done to iocontrol.0.user-enable-in and see if that does what you want.
16 Jan 2015 06:44 #55056 by clematites93
Thank you for your answer. I am going to try.
Besides, I read (Derived Ted Hyde's original hm2-servo config)
# position command signals
net emcmot.00.pos-cmd axis.0.motor-pos-cmd => pid.x.command
net motor.00.command pid.x.output => bldc.0.value
net motor.00.current bldc.0.out => hm2_HOSTMOT2] (BOARD).0.8i20.0.current
#net motor.00.current hm2_[HOSTMOT2] (BOARD).0.encoder.0.velocity => hm2_[HOSTMOT2] (BOARD).0.8i20.0.current
What is the meaning of this last line? Even if it is "commented", it seems in contradiction with the previous one
16 Jan 2015 06:55 #55058 by andypugh
It makes no sense to me at all.
The following user(s) said Thank You: clematites93
17 Jan 2015 06:16 #55109 by clematites93
Now with F1 (Axis), the motors turns and ends its "homing sequence"
With halmeter--> bldc.0.offset-measured show a value
1) Needs it to use this value in the hal file ?
After, with F2, motor turns very little and Axis always send back a "join error";
2) Please, what is the problem ?
17 Jan 2015 10:25 #55114 by Todd Zuercher
Replied by Todd Zuercher on topic getting started with 8i20
Sounds like now it is time to tune the PID.
18 Jan 2015 03:40 #55131 by clematites93
my motor is used and I have little information about it
I would say its power is less than 1,5 kw
it has an encoder Heidenhain ROD 426 2500
In my Hal file :
Encoder feedback
setp hm2_7i43.0.encoder.01.counter mode 0 # quadrature
setp hm2_7i43.0.encoder.01.filter 1
setp hm2_7i43.0.encoder.01.index-invert 0
setp hm2_7i43.0.encoder.01.mask 0
setp hm2_7i43.0.encoder.01.mask-invert 0
setp hm2_7i43.0.encoder.01.encoder.scale 2500 # do you think I put a right value regarding the encoder?
BLDC setup
setp.bldc.0.initvalue 0.2 # current during homing sequence only ?
setp.bldc.0.poles 4 # put randomly
setp.bldc.0.scale 2500 # but I've also tried -2500
setp.bldc.0.rev 0 # is it rotation sense ?
In order to tune PID i used CNC Servo Axis Calibration. After having tried different PID values I always have the same error "Join error"
Any other thing you might think of to try to resolve the problem apart from PID?
18 Jan 2015 05:08 #55132 by PCW
Replied by PCW on topic getting started with 8i20
This surely should be 10000 (or -10000)
Time to create page: 0.069 seconds
