My code is modified from the original project from this thread. I use the esp-8266-1, in an Arduino uno (which will eventually be a nano - when I can find a suitable enclosure to fit the hardware buttons - but that's another struggle)....
The difference in my project, is that it does not re-assign input/output pin mapping on each packet exchange. My project sets up inputs and outputs one time in the setup function. I am not sure how much time is gained with that - but I can't see it being so latent to notice without gauging with a scope or a timed circuit.
The second difference in my project from the original posting on the thread, is my encoder handling procedure. I send the difference in movement of the MPG dial encoder to HAL, instead of updating the A/B hardware pins into HAL copying the Arduino hardware pins. If somebody was really wrenching fast on the encoder, faster than the latency of the processing in packets - my code only sends the difference in position from the last packet - VS - copying each signal from the encoder.
I only intended to use this project to toggle all the user input MPG jogging buttons, run, stop, home, zero. All the basic manual navigating & targeting to setup the machine. If code was not executed in the time it takes to send 1/2 of a packet and transfer that information to handle other cycles - it would be so small, I would again need a scope to measure that difference in time since it could be in microseconds. The speed of my hand & eyes to press emergency-stop is a whole lot more time, than it takes to transfer that signal from the Arduino button - through WIFI, to ethernet - into HAL.
If by comparison to a MESA card in terms of speed of I/O from motor positioning encoder feedback, the MESA card would be faster. I can't give you any statistical figures on tests for any of that since I do not own any MESA cards. For the last 9 years I've done everything I needed to do with dozens of machines I built - and 2 Bridgeport Boss retrofits using only parallel interface cards and a heap of wires, switches and lights.
