andypugh wrote: This is the code that reads Mesa encoder values:
github.com/LinuxCNC/linuxcnc/blob/master...tmot2/encoder.c#L862
And, if you care, this is the vhdl that defines the encoder on the FPGA
github.com/LinuxCNC/hostmot2-firmware/bl...r/src/qcountersf.vhd
DocStein99 wrote: Ok, well you've just gave away all the magic. I was a little mystified before, but now I can see the code is as simple as writing an ansi .C class object.
DocStein99 wrote: I figured since the last time I did a setup, someone surely added a feature to toggle i/o pins through a tcp socket.
andypugh wrote: linuxcnc.org/docs/2.7/html/man/man1/linuxcncrsh.1.html
