RT HAL Component using an externa library and API
20 Feb 2015 16:18 #56140 by mdurna
Dear Andy and Peter,
We are checking the links.
I appreciate for your guidances. For the moment we plan the following:
Plan A:
1. Test our USBized sensor interfaced with our userspace HAL component using a known test object for its "real-timeness",
2. If it is not satisfactory we will modify Andy's mesa_uart.comp and write a real-time parser HAL component and convert the byte array to real number to be used in our application,
3. Also syntesize a suitable configuration for our 5i23+7i37 system interfaced with a RS422 transceiver.
Plan B:
Hope this works. In the worst case we plan to collect and store sensor data against the encoder using a dedicated board like Arduino or Teensy in real-time and download the acquired data to LinuxCNC PC off-line over USB and a Python code.
Thanks again all.
Best regards,
Mehmet
20 Feb 2015 16:19 - 20 Feb 2015 16:22 #56141 by mdurna
Dear Peter,
I will try to make the bitfile according to wiki.linuxcnc.org/cgi-bin/wiki.pl?Editing_MESA_Bitfiles and ask for your help if I stuck in the process.
Thanks for your helps.
Best regards,
Mehmet
Last edit: 20 Feb 2015 16:22 by mdurna. Reason: Correction
Time to create page: 0.075 seconds
