Configuring LinuxCNC
HAL
Adding fourth axis to delta
Thank you received: 0
29 Jul 2015 01:27 #61001
by furkanyilmaz11
Hi all,
I have a delta robot based on linuxcnc. I will use it for pick and place applications. I want to add fourth axis to this delta as a rotary axis. My delta is three axis based but I want to add fourth axis to rotate my objects which objects robot picking and placing.
As I said I want to add this axis for rotate the objects. I want to control this axis 0-360 degrees. How can I add this fourth axis? Or any other suggests?
Thanks in advance...
HAL
Time to create page: 0.040 seconds
