Get current state of LinuxCNC trough HAL/Python
- minitreintje
09 Aug 2015 01:08 #61230
by minitreintje
Get current state of LinuxCNC trough HAL/Python was created by minitreintje
Hi everyone,
I need to check the current state of LinuxCNC trough a HAL pin which will trigger a Python script. This is necessary since I need to execute a command before LinuxCNC exits.
Can somebody help me with that? I don't know how I can check trough HAL if the user close LinuxCNC.
Regards,
Dylan
Regards,
Dylan
- Thank you received: 2167
09 Aug 2015 02:42 #61233
Replied by cmorley on topic Get current state of LinuxCNC trough HAL/Python
What state of linuxcnc are you interested in?
How will you launch the script?
A python program can poll alot of info from linuxcnc.
www.linuxcnc.org/docs/2.6/html/common/python-interface.html
- phillc54
- Thank you received: 2096
09 Aug 2015 06:55 #61235
by phillc54
Replied by phillc54 on topic Get current state of LinuxCNC trough HAL/Python
SHUTDOWN in the HAL section may help.
<www.linuxcnc.org/docs/html/config/ini_co...id_sub_hal_section_a>
- minitreintje
09 Aug 2015 14:04 #61236
by minitreintje
Replied by minitreintje on topic Get current state of LinuxCNC trough HAL/Python
@phillc54
I tried to use the HAL shutdown file but the command doesn't come trough.
LinuxCNC communicates with an Arduino (serial) trough Python, in the shutdown HAL file I put a parameter. The Python script reads the parameter each time.
However, I think the Python script is closed first before the LinuxCNC executes the shutdown HAL file. I tried to make a second Python script which will be called only when LinuxCNC shutdown but that doesn't work either.
@cmorley
I need to know when a user closes LinuxCNC so that I can execute a command to the Arduino (serial).
Dylan
@cmorley
Dylan
10 Aug 2015 01:37 #61248
You could use gladevcp with a python handler file - I believe the manual on gladeVCP talks about catching linuxcnc closing.
You could use a python 'user HAL component' to do nothing but wait for an exception (HAL closing).
The exception code could do what you want.
Hope that helps
Chris M
Hope that helps
Chris M
- minitreintje
10 Aug 2015 02:11 #61252
by minitreintje
Then I need to convert my PyVCP to GladeVCP.
I read somewhere I can add a keyboard hotkey to a GladeVCP button also that's the second thing I was looking for
Dylan
Dylan
- Thank you received: 5013
10 Aug 2015 20:45 #61277
Replied by andypugh on topic Get current state of LinuxCNC trough HAL/Python
I think the way to do this might be to use a shutdown/hal in the INI which calls your Python script.
You seem to say that you have tried this, but didn't say what syntax you used.
You probably need the shutdown.hal file to sayThen the HAL file should wait for the python file to report finished before continuing.
It is likely that the Python script needs to create a hal component name for itself and signal ready() to handshake properly.
www.linuxcnc.org/docs/html/hal/halmodule.html
loadusr -W yourfile.py
- minitreintje
11 Aug 2015 23:20 #61299
by minitreintje
I tried that but the Arduino just does nothing.
I also tried with a HAL pin that waits until it's activated by shutdown.hal by:
which also does nothing.
Dylan
setp arduino.linuxcnc-shutdown 1
Dylan
11 Aug 2015 23:28 #61300
Try "show pin" in the shutdown hal, and then start LinuxCNC from the command line.
That should indicate whether the HAL file is being executed or not.
- minitreintje
26 Aug 2015 14:23 #61801
by minitreintje
Sorry I was on vacation, I will try it today and let you know.
Dylan
Dylan
